Home > Technical (L322) > Electric seats and steering control fault
samp5679
Both front seats have stopped working so has the electric steering wheel adjust any ideas ??? Is fuse in fuse board or is there another in seats???
Simon
Post #214207 4th Oct 2013 7:13pm
I'd check the connector to the ECU under the drivers seat first. Thumbs Up
Post #214236 4th Oct 2013 8:03pm
samp5679
and now the radio has stopped working great for owning car 1 week
Post #214733 6th Oct 2013 7:39pm
is the battery ok? ... - .- -.
Post #214738 6th Oct 2013 7:48pm
samp5679
battery is pretty new,, it happens after driving for a while like something is over heating, now stereo/radio has turned off
Post #214740 6th Oct 2013 7:50pm
daveo
i think the radio is something different, on the driver seat is the electric switches loose, the multi plug on the switch pack will cause both them probles if loose there or under the seat as stated. V8 facelift Range Rover Autobiography 22" wheels.
Post #214751 6th Oct 2013 8:02pm
samp5679
I have had a fiddle with connector do you mean under the seat or on the side ????
simon
Post #214753 6th Oct 2013 8:07pm
daveo
try the plug on the side of the seat behind te switch valance,
does any of the switches on the seat work. V8 facelift Range Rover Autobiography 22" wheels.
Post #214756 6th Oct 2013 8:14pm
samp5679
nothing works both seats and steering adjust then tomorrow it might work for a while then off again , radio cd has gone off also
Post #214757 6th Oct 2013 8:15pm
samp5679
caught fire
seat and steering adjust was the wiring to the back part of seat for lumbar due to being crushed and split , it actually caught fire bellowing smoke out so careful if this happens to you, all fixed now , coolant light fixed it was sensor £9,00 for that just oil leak and bodywork imperfections then happy days ,,,, for a while
Post #215696 10th Oct 2013 4:59pm
