Home > Technical (L322) > Has my head gasket gone ? |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Unfortunately it looks like the head. Plus side if it is that the oil has gone into the water not the other way round. Sorry. A garage will be a lot more help than me. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
6th Oct 2013 8:09pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1323 |
Check out the cheap things first IMO
6th Oct 2013 8:13pm |
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 |
Yep be on the blower to Dan first thing.
6th Oct 2013 8:28pm |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 |
Hi mustard where in the north are you?
6th Oct 2013 8:53pm |
Hello Crookedm,
6th Oct 2013 8:59pm |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Ford Hill, Wirral. Not Merseyside Posts: 554 |
Just read the post... So sorry mate |
6th Oct 2013 9:03pm |
Sorry about that! PM sent to you.
6th Oct 2013 9:24pm |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
The only way to know for sure will be some proper tests ie compression etc. However with the cooling system full of that much oil & no trace of coolant the other way I would suspect oil cooler. Did you have a lot of pressure in the cooling system? Cleaning that oil out will be a pig for some poor soul though. good luck Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
6th Oct 2013 9:39pm |
I was only just thinking the other day after all Ive done is pamper it how reliable it actually is and bosh it fekkin breaks down on me....
6th Oct 2013 9:53pm |
I doubt very much anything you have done would cause it,gaskets fail & so do coolers but on a positive note if it is the headgasket & done properly it should do many tens of thousands of miles with no more probs. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
6th Oct 2013 10:00pm |
Do you know what that sort of service costs ? Ive got to try sleep tonight |
6th Oct 2013 10:05pm |
I would be guessing but gen parts depending on how many holes your headgasket has (1-3 denote thickness) between 50 & £100 plus headbolts & other gaskets,coolant antifreeze,oil,filters,flushes etc I would guess an indy inc vat would be about £800. Also the head may need Skimming which you may have to budjet another £50.00 + extra labour to strip down head. Worst case a Grand. But thats only a worst case guess. Hope that helps you sleep tonight & if the engine was due a service then you could offset some of that cost for the repair. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
6th Oct 2013 10:20pm |
The horrible thing is Ive just had it major serviced as well, all that lovely golden fresh juicy oil......turned into black muck, all the fresh coolant anti freeze mix ready for winter, lovely fresh filters and so on
6th Oct 2013 10:46pm |
Plant Member Since: 01 Oct 2013 Location: Wirral Posts: 38 |
I'm on the Wirral, could I ask who the Indy was please? Thanks |
6th Oct 2013 10:52pm |
