Home > Technical (L322) > Ride hight of 4.2SC
philmc79
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Ride hight of 4.2SC
Could anyone let me know of the correct on the road ride hight measurement from the bottom of the wheel arch to the centre of the wheel hub as my rear suspension seem to be low at the rear, i have just taken our horse trailer to have it serviced and the service centre tells me that the hight of the tow hitch is a bit low and having now had a look at the back of the RR it sits lower at the back than at the front, the suspension seems to go up and down ok from access hight to off road but it does seem a bit low at the back.
Seems to squat on the back.
Any help would be appreciated
Post #214414 5th Oct 2013 11:14am
i just quickly copied this from the workshop manual [download link in the wiki]
Post #214415 5th Oct 2013 11:20am
philmc79
Thank you very much it is 40mm to low so i guess it needs some attention.
Post #214417 5th Oct 2013 11:25am
seems like..the IIDTool from GAP diagnostics will get it to whatever height you want, providing theres no underlying problems .. ... - .- -.
Post #214419 5th Oct 2013 11:28am
philmc79
Got a ELM327 and a peace of software from RSW that will set up the bags up so they say, i will have to see if it works and report back here, having a nightmare with the people i bought the car off as it is under warranty and they say there is nothing wrong with it although is is 40mm lower than it should be.
Post #214489 5th Oct 2013 3:45pm
Note for SC "club members" Wink ride height is the same as the lowly TD6 Very Happy .
Post #214490 5th Oct 2013 3:48pm
philmc79
As i am new to all this as it is my 1st FFRR use to have a 4x4 sorento, i have yet to find the OBD connector on my RR, and fighting the seller to do his bit with a few other defects Confused
Post #214493 5th Oct 2013 3:53pm
philmc79
The guy in the states tells me the all comms only talks to the BMW RR and not the 2008 Ford one's have you tried any 08 cars with your all comms, if so will you let me know.
Post #214496 5th Oct 2013 3:59pm
Hi philmc79
As far I know he is right, works only for the '02-'05 BMW canbus vehicles.See here:
http://www.rswsolutions.com/index.php?opti...;Itemid=81
It is a 20 minute job with the right tool to sort out the ride height, so the people you bought it off, if they say there is nothing wrong, show them the datasheet and the measurements you have made. If it is meant to be 483mm +/- 2mm and it is 40mmm out, then there is something wrong!
OBD port is above the bonnet release catch / below the light switch on the Driver's side (RHD) .
Post #214536 5th Oct 2013 7:03pm
philmc79
Thanks for the info i will keep you up to speed on the out come and the new software from RSW
Post #214645 6th Oct 2013 4:06pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Ride height might be the same as a TD6 but the struts and arbs certainly differ Wink
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #214690 6th Oct 2013 5:51pm
