Home > Technical (L322) > Ride hight of 4.2SC |
philmc79 Member Since: 10 Sep 2013 Location: Hyde Cheshire Posts: 94 |
Could anyone let me know of the correct on the road ride hight measurement from the bottom of the wheel arch to the centre of the wheel hub as my rear suspension seem to be low at the rear, i have just taken our horse trailer to have it serviced and the service centre tells me that the hight of the tow hitch is a bit low and having now had a look at the back of the RR it sits lower at the back than at the front, the suspension seems to go up and down ok from access hight to off road but it does seem a bit low at the back.
5th Oct 2013 12:14pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35161 |
i just quickly copied this from the workshop manual [download link in the wiki]
5th Oct 2013 12:20pm |
Thank you very much it is 40mm to low so i guess it needs some attention. |
5th Oct 2013 12:25pm |
seems like..the IIDTool from GAP diagnostics will get it to whatever height you want, providing theres no underlying problems .. ... - .- -.
5th Oct 2013 12:28pm |
Got a ELM327 and a peace of software from RSW that will set up the bags up so they say, i will have to see if it works and report back here, having a nightmare with the people i bought the car off as it is under warranty and they say there is nothing wrong with it although is is 40mm lower than it should be. |
5th Oct 2013 4:45pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Note for SC "club members" ride height is the same as the lowly TD6 .
5th Oct 2013 4:48pm |
As i am new to all this as it is my 1st FFRR use to have a 4x4 sorento, i have yet to find the OBD connector on my RR, and fighting the seller to do his bit with a few other defects |
5th Oct 2013 4:53pm |
5th Oct 2013 4:59pm |
Hi philmc79
5th Oct 2013 8:03pm |
Thanks for the info i will keep you up to speed on the out come and the new software from RSW |
6th Oct 2013 5:06pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
Ride height might be the same as a TD6 but the struts and arbs certainly differ
6th Oct 2013 6:51pm |
