Home > Off Topic > Needed a new coffee table...
Page 1 of 3 123>
So, I needed a new coffee table. As you can see by my current use of two rather horrible coffee tables I need quite a large one.
Also, I wanted something a bit more interesting. I thought about the V12 one they have on Top Gear, but it's not a very interesting engine and also the wrong size for my needs.
Thus began my quest.
So I called my new friend Terry and he said he might have something. I hitched up my trailer (this was in Feb) and set off.
Through Belgium.
Across the channel.
To Dover.
And across the border to Scotland, where I got a nice welcome.
Actually, I only needed to go to Carlisle, but thought I'd pop over the border as I hadn't been to Scotland for 25 years!
Picked up my new coffee table.
And a few other things.
And headed home.
It took some unloading.
So you're probably wondering what kind of coffee table it is? Well, it's a Bristol Hercules 14 cylinder sleeve valve radial coffee table, as fitted to, amongst other aircraft, the magnificent Bristol Beaufighter.
Many Halifax's.
And many Wellingtons.
Mine is a slightly later, post war one which was fitted to a Vickers Varsity transport plane.
So you're probably thinking '....er Kurt, that's not a coffee table, that's an aeroplane engine', and also maybe questioning my sanity - something I regularly do myself.
So here's the idea I have, just on a slightly larger scale.
See, I'm not so insane after all! :D
Post #214277 4th Oct 2013 10:26pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Maybe not insane, but clearly barking mad!! We need pics of the finished coffee table! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #214281 4th Oct 2013 10:33pm
Shocked
Post #214282 4th Oct 2013 10:35pm
Absolutely fantastic... What a great project. That'll look great when it's finished. Previously..
Post #214286 4th Oct 2013 10:46pm
Jeez you must spend a fortune on your projects Whistle ====================================
Post #214292 4th Oct 2013 10:58pm
Ok, so here's the plan.
Coffee tables can't be tall, and seeing as it's going in a little wooden house this one can't be heavy. It currently weighs about a ton.
Here's the engine from the side with some labeling I've added.
For a coffee table I'm interested in the cyclinders and the crankcase, and that will give me a height of 48cm, which is only 3cm more than my current tables. Engine diameter is 125cm - which is pretty ideal for what I want. Just as well as getting the larger 18 cylinder Centaurus would've been nigh on impossible!
So what I need to do is dissmantle the front - the prop reduction gear and the sleeve crank drive gears. I also need to dismantle the rear - the magneto's and the supercharger. I've already removed the carb (which was enormous).
However, this gives me a problem - how do I dismantle the rear of the engine when the engine mounts are there?
My plan is to remove the cylinder barrels first, and then make a temporary mount to hold the engine from where the cylinder barrels are bolted on. Then I'll have access to both ends of the engine. The barrels themselves will need treating/painting as all the steel bolts are badly corroded and the aluminium itself looks rough and industrial. Anyone have any tips of a good finish? All suggestions gratefully received.
With all that removed it should be a lot lighter, but still bloody heavy. So the next thing would be to remove the internals. Here's a picture of what they look like on another engine.
I think they're stunning to look at, even though in this picture you can't even see the crank and rods. These are the crank and rods from a Bristol Centaurus which is a similar engine, just with 18 cylinders.
So I'm thinking to re-assemble these from the supercharger forwards and make what would effectively be a glass crankcase so you can see it all, and make a dining table with it.
Post #214296 4th Oct 2013 11:33pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Bold statement but beautifull
Post #214297 4th Oct 2013 11:36pm
Googsy
Looks amazing Shocked
What's your bed like Whistle Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #214299 4th Oct 2013 11:52pm
ebajema
All I can say is WAUW Bow down Bow down Bow down Thumbs Up Thumbs Up Thumbs Up MY 2010 5.0 SC Galway green and sand interior!!
Post #214324 5th Oct 2013 8:36am
RCusden
Wales
Wow, your projects are great Bow down Thumbs Up
Post #214327 5th Oct 2013 8:55am
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Would love one ! Where can I get an engine ?
Post #214329 5th Oct 2013 8:56am
wouldnt it have been cheaper and easier to go to ikea? Laughing ... - .- -.
Post #214357 5th Oct 2013 10:10am
Best get on the bench weights david so you can lift it into the house Smile
Are you thinking of wiring up some kind of motor so it can be turned on and turned over at a very very slow RPM??
Personally i think powder coating could be the way to go as its the easiest way to get a good even finish over the whole lot. Then if you want a clean finish a few clear coats on top baked off for a few hours at a low heat should cure it all off nicely.
Maybe do the piston tops red if they are to be exposed and then contrasting red/blue/green for any internal moving parts that can be seen to make it easier to see them Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #214369 5th Oct 2013 10:34am
TugRR
I like this very, very much Bow down
Makes all those V8 coffee tables look common !
Thumbs Up Where do you go after one of these . . . ?
Post #214371 5th Oct 2013 10:39am
Here's a very short but excellent animation on how sleeve valves work in a Bristol Hercules.
http://www.youtube.com/watch?v=_vrvep_YOio
I wrote this article a few years ago during an idle evening. Just a little industrial history on sleeve valves and why I find them so interesting. Maybe it's boring for you guys, in which case - sorry for being such a nerd.
Quote:
Internal combustion engines have poppet valves � it�s a given. And because that�s been the case for so long it must be because they�re superior to any other kind of valve?
Well actually, poppet valves have dominated engine design for so long only because of an accident of industrial history, and they are not necessarily the best valve design.
I read a biography of an interesting character called Sir Roy Fedden, who was an aero engine engineer at Bristol from the end of the First World War till the end of the Second. I read it because I have an interest in sleeve valve engines
Feddon had a natural affinity for air cooling and for radial engines, believing them to be lighter and more powerful than inline water cooled engines, and these advantages offset any aerodynamic disadvantages they may have. Yet by the end of the 1920's Feddon reached the same conclusion as Ricardo, that the power of these engines would be restricted by the problem of detonation - the fuel/air charge exploding due to the increases in pressure and temperature as the cylinder charge is compressed, rather than being ignited by the spark plug, and in so doing, destroying the engine very quickly. The four valve head was a help in reducing detonation, but was very difficult to fit onto a radial engine that used push rods to operate the valves, especially so on a radial with two or more rows.
But Feddon believed the four valve head only mitigated the problem and that the best solution was to do away with poppet valve entirely, to give a better combustion chamber shape, provide more reliability, and remove a principal source of detonation - the very hot exhaust valve.
Feddon turned to sleeve valves, which had been experimented with before but never very satisfactorily. In a sleeve valve engine the cylinder wall rather than the cylinder head has inlet and exhaust ports in it. Between the piston and cylinder sits a sleeve that is moved vertically and radially by a series of gears driven directly from the crank to expose the ports in the cylinder wall - allowing gasses to be inducted and exhausted.
Sleeve valves were a huge engineering challenge for the day, and hugely important to Britain�s competitiveness in the aviation industry, and later to defeating Germany. To give an idea of the resources dedicated to the project, ten time more was spent on the development of sleeve valves than the early jet engines that came nearly 10 years later.
The engineering challenge stemmed from the sleeve. Endless experiments were made to find a metal that was both a good cylinder liner, was light and had the same coefficient of expansion as the piston and the cylinder itself. Eventually, one was found and the design worked. Fedden was able to raise the compression ratio significantly compared to a two poppet valves, with a corresponding increase in power and efficiency.
However, making the sleeves to the correct tolerance was impossible unless each sleeve was hand polished to fit each respective cylinder, a process completely unacceptable for the volumes required. Eventually, at a time when the projects detractors were gaining in number and both the government and Bristol were loosing faith in Feddon, a solution was found by accident. A machinist had used a worn tool instead of a new one, and the tool had polished rather than cut. Bristol's factory now began turning out large numbers of sleeve valve radial engines - the two row 14 cylinder Hercules, to be used on Bristol's own Beaufighter, the Short Stirling, the Vickers Wellington, the Handley-Page Halifax, and even on some Avro Lancaster's.
And what superb engines they were. The Hercules and the later 18 cylinder Centaurus, compared to the rival American radials with their two valve heads, were smoother and quieter, in the cruise they used only two thirds of the fuel, and they lasted up to 50% longer between overhauls.
How they compared to the water cooled inline engines with their 4 valve heads is a different matter. By the early 40's poppet valves had broken through the detonation constriction Feddon and Ricardo had thought would hold them back. High octane fuel was available, and the exhaust valves were kept cooler by filling them with a metal of very high heat conductivity (sodium), allowing more heat to be dissipated through the valve stem.
The only empirical comparison of sleeve valves vs. a four valve engine was done towards the end of the war by Stanley Hooker at Rolls Royce. RR was experimenting with a 2-stroke V12 using both direct injection and sleeve valves, which was theoretically both efficient and hugely powerful. This ambitious project was running into trouble and Hooker was brought in to advise the board whether it should be scrapped, which is what his advice was.
Hooker was an aerodynamicist with a big reputation. His early work at RR had noticeably improved the performance of the supercharger on the Merlin, a state of the art design many had thought was already close to maximum practical efficiency. He then introduced two-stage supercharging on the Merlin, doubling power at 30,000ft and allowing the Spitfire to convincingly meet the challenge of the FW190.
He found no advantage in sleeve valves, but his analysis was extraordinarily narrow, consisting of a comparison of air flow through open valves. No proponent of sleeve valves had said air flow was a principal advantage, so why did Hooker only look at this area?
It could be it was because Hooker was an aerodynamicist, but this is belying his broader abilities. A more likely explanation was that he resented being temporarily pulled off jet engines to look at a project he thought was irrelevant. To him the engine could be twice as powerful as the best piston engine, but it still wouldn't beat a jet. He knew jet engines would be the future, and he proved this to the air ministry in a paper about a future fighter.
The requirement was for an aeroplane that could fly at 400mph at low level. Feddon proposed an 18 cylinder sleeve valve engine of even larger dimensions than the huge Centaurus, and producing about 4000bhp, and with a development time of 3-5 years. Hooker pointed out that with some subtle revisions to the compressor and turbine of the existing Nene jet engine, 500 mph at low level was readily available. The Nene was also very cheaply made compared to a huge piston engine, and a single Spitfire was more maintenance hungry than a whole squadron of Meteors.
Soon after, all sleeve valve development stopped, together with pretty much all piston engine development. Bristol replaced Feddon with the newly recruited Hooker (who�d fallen out with his boss at RR) when the former proved too attached to his beloved sleeves.
Piston engine development was now passed to the car manufactures, many of whom hadn't moved from side valves to overhead valves, yet alone 4 valves, and they were far too concerned with cost to think about sleeve valves. It wasn't until the eighties, when turbo charging and lots of money hit Formula One before piston engine development caught up with the state of the art in the late 40's. In fact, Paul Roche at BMW later read a book about World War II engines and found out they went through exactly the same process as he'd done concerning inter-cooling and exotic fuels, never mind turbo compounding. He confessed he could have saved himself a lot of trouble by reading the book before hand!
So by an accident of industrial history this great technology had been forgotten.
That is, apart from by one Keith Duckworth, one half of Cosworth. He remembered them from working at Bristol in his youth, and experimented with them again in the 70's, apparently quite easily getting close to the specific output of contemporary Formula One engines, and concluded that they could be more easily and better made than in the 40's by using modern methods. However, as is often the case with engineering, a superior but undeveloped technology often has a difficult or impossible time dislodging an inferior but developed one.
Post #214373 5th Oct 2013 10:41am
Page 1 of 3 123>
