Home > Technical (L322) > rear wash/wipe woes |
growlygrowler Member Since: 04 Oct 2013 Location: Notts Posts: 4 |
4th Oct 2013 6:29pm |
Thanks. Good idea. BTW I've been trying to type for the last 5 minutes but couldn't stop laughing at your avatar. Excellent! When I lived overseas that was what I missed about British humour. You should send the photo to Private Eye.
4th Oct 2013 7:21pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3969 |
4th Oct 2013 7:26pm |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
I would check the wiring in to the tailgate, Common place for wiring to break as it constantly moves as it comes out of the car into the tailgate. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
4th Oct 2013 8:31pm |
Aha. I need to double check this in the morning when the light is better and I can be doubly sure, but a quick test with the ohmmeter indicates there to be no continuity from fuse #10 in the boot to the red & white wire at the wiper.
4th Oct 2013 8:48pm |
Having taken the fuse block out, the red & white wire had come adrift at the multi plug attaching it to the loom. It looks like the last few strands had overheated. I'm not sure how this would have happened since I've never had the component out before. The motor on the tailgate has apparently seized up as the new one works fine, so once I've fitted it I'll pull the old one to bits and see what went wrong Thanks for your help. |
5th Oct 2013 11:00am |
5th Oct 2013 11:12am |
