Home > Technical (L322) > 5 min into every drive.air suspension inactive hdc abs brake
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
Swapped out the ABS sensor, what a nightmare when they're seized up... That did not remedy the problem. Mad
Post #21252 29th Jun 2010 12:32am
tonybm730
2003 Range Rover Vogue 4.4 V8 Zermatt Silver
Hi mate sounds like just the same thing that happened to me last month. All the same warnings, turned out to be the brake light switch on the brake pedal,cost £27.07p to supply and fit at a place near me called LANDRANGER. So dont dispare mate could be nothing Very Happy
Post #21280 29th Jun 2010 5:02pm
brad s1
was yours an intermittent issue? or lights on all the time? Very excited to hear it could be something so simple. although I don't see this part in the rave manual.
Thanks for the post... I noticed today it more often than not the errors happen during braking, interesting.
Anyone know more about this brake switch? sounds like it can either be a nightmare to access or a breeze, wouldn't mind shotgunning this issue with that replacement.
thanks again
Post #21298 29th Jun 2010 8:33pm
brad s1
What exactly does the brake light switch do? I unplugged it and removed it, looks like its magnetic. While it was pulled I decided to drive down the street to see if I instantly got the errors I'm familiar with... Didn't trigger anything, nor did it seem to have any affect on the brake lights... Unless it controls only the 3rd brake light, but I couldn't see that one.
On edit, when it's unplugged the lights are always on, lol... Did some more research and discovered freelanders have an issue with the switch that triggers ABS among other things...
Really hoping this is the cause, nobody has been able to figure this out.
Post #21304 29th Jun 2010 10:35pm
tonybm730
Hi mate had mine diagnosed at the garage were i take my car, i'm not very tech minded so the guy told me that the car thought the brakes were on all the time, even though they wern't he said this was sending all the wrong messages to the other systems. So within 5 mins of driving on they came, HDC INACTIVE, ABS NOT WORKING, BRAKE WARNING LIGHT, AIS SUSPENSION NOT WORKING ,AND ALSO TRANS FAILSAFE MODE every time i went out. He put his diagnostic pad on all pointed to brake pedal switch the one near the brake pedal itself took him about 10 to 15 mins fiddleing all done never had a warning light since hope this helps mate
cheers Tony
Post #21335 30th Jun 2010 4:12pm
brad s1
cheers Tony
Greatly appreciated, when I pulled mine yesterday it looks like the previous owner had some hack mechanic working on that area, screws/bolts missing and the switch itself was not in perfect condition. I order the switch which comes in friday, we'll see what happens.
what year is your range that had this issue?
Thanks again.
~Brad
Post #21336 30th Jun 2010 4:36pm
tonybm730
Hey Brad my fingers are crossed for you hope it works as well as mine did i have a 4.4 02 Vogue
Post #21350 30th Jun 2010 10:52pm
brad s1
Thanks for the posts tonybm, greatly appreciated, this forum is great Very Happy
I'm actually going to pick up the switch now, I'll post back in a day or to with the results.
Thanks again!
Post #21486 2nd Jul 2010 2:35pm
brad s1
Well the brake sensor didn't remedy the problem, during the test drive with the new sensor I found myself close to an independent land rover shop, so they were kind enough to plug it into test book and diagnose the problem...
Apparently the yaw sensor isn't functioning properly and they're almost positive that's the issue. I guess there is a recall on that, if for some reason the dealer won't honor it I'll just fit a new one.
It's located under the center console towards the back under the air vent, the entire center console needs to be remove to access it.
Post #21530 3rd Jul 2010 7:39pm
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Did this work?
Post #31937 15th Oct 2010 7:36pm
