Home > Technical (L322) > 5 min into every drive.air suspension inactive hdc abs brake
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
Since I've owned my US 2004 HSE it has done this. 5 minutes into a drive, or instantly when leaving a rest stop pulling onto the highway I get...
Air Suspension Inactive
HDC Inactive
Brake warning light
ABS warning light
DSC warning light
The suspension locks to standard height, the truck actually drops itself slightly when this happens.
When the rover is parked and turned off, the suspension pops up slightly back and then front, on the next restart the codes are gone and everything functions proper for 5 minutes, then this happens again.
When off road moving slowly down a trail, moving slowly over snow, this does not happen... Only 5 minutes into a regular commute do these codes appear.
My ABS sensors all looked fine, I decided to pull the front drivers side on a hunch... It was seized into the hub.. I tried to get a flat head screw driver behind it, and it essentially crumbled. Should those pop right out? Is it normal for them to seized to the hub?
The wiring itself looks good, but the abs sensor itself is a melted mess in the hub.
Anyone have any experience with this problem? What was your fix?
Someone told me it could be a steering angle sensor, but that seems to function properly when I pull the battery and re-calibrate it locking the steering wheel left to right.
Any help would be greatly appreciate
Post #21076 25th Jun 2010 4:56pm
lrdaft
Scotland 2011 Range Rover Vogue TDV8 Santorini Black
is your steering wheel centralised?
Post #21101 25th Jun 2010 9:17pm
brad s1
As in turning the steering wheel lock to lock once you've wired the battery back in? If so yes that's been done and it clears the codes as it should...
But as soon as a commute gets under way all the codes come up.
Post #21109 26th Jun 2010 1:27am
lrdaft
no what i mean is the steering wheel in the centre position when driving on a straight road?
Post #21136 26th Jun 2010 2:51pm
brad s1
it actually isn't, the alignment of the car does seem off... slight right dip to the steering wheel to go straight.
Post #21142 26th Jun 2010 4:41pm
lrdaft
that will cause your faults, check for worn ball joints and set wheel alignment
Post #21172 27th Jun 2010 6:14pm
brad s1
I see a recall for yaw sensor... Could that be related?
As far as worn ball joints, I just did the whole front suspension a month ago, tie rod ends/ uppers/ lowers/ etc...
Should I be going to the dealer for the alignment, or will any reputable place do?
Post #21178 27th Jun 2010 7:31pm
lrdaft
anyone who can set four wheel alignment
make sure steering wheel is straight as this is critical
Post #21180 27th Jun 2010 8:05pm
brad s1
Interesting, I've never heard of this causing a problem before.
Post #21181 27th Jun 2010 8:19pm
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
Me neither can you explain alittle why this would cause a problem (i'm a newbie)
Post #21184 27th Jun 2010 8:39pm
lrdaft
steering angle sensor fault is registered because wheel is out of alignment
this causes hdc fault,which is controled by abs,because abs is in limp home mode air susp shuts down as it recieves various data from abs on the can bus line
i have repaired many of these after many visits to main dealer never had fault reappear
Post #21211 28th Jun 2010 10:03am
paul_h_8
Thanks for above, my steering is out very very slightly and i've had no problems with suspension but ill get a 4 wheel lazer alignment done and make sure steering wheel is straight. Thanks once again
Post #21214 28th Jun 2010 10:12am
brad s1
Very interesting... and I must admit, the alignment has been screwed for a long time...
Your input is greatly appreciated, I'll get it down to the alignment shop asap
Post #21230 28th Jun 2010 4:31pm
I've never seen an L322 FFRR which doesn't have a steering wheel tilted slightly to the right when driving straight ahead. Shocked Even new ones! Discovery 4 HSE
Post #21234 28th Jun 2010 6:01pm
brad s1
Car needs an alignment anyway... Worth a try, I've tried many things to correct this. Dealer as well as independents have looked at the car, updated software, replaced sensors, etc etc etc to no avail.
Post #21242 28th Jun 2010 6:44pm
