Home > Maintenance & Mods (L322) > Tow Bar Armature - Gaskets ? |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Fitting instructions: http://www.fullfatrr.com/forum/post205899.html#205899
30th Sep 2013 1:52pm |
Mark.abersoch Member Since: 23 May 2013 Location: Wirral Posts: 148 |
I think you are meant to have some. I fitted a used in on mine the other week and just used some silicone!
30th Sep 2013 2:04pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Thank you, gentlemen.
30th Sep 2013 3:03pm |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
You will find a thin foam gasket left stuck to the car after you remove the existing brackets, if it's like mine. I fitted a used bar, like Mark said, use a bead of silicone and all should be well. |
30th Sep 2013 9:54pm |
Simple1 Member Since: 01 Jun 2013 Location: Somerset Posts: 112 |
As stated, when I fitted mine, the seals from original bar remained so I have two new ones in a bag if you need them TDV8 Vogue SE 2009.
2nd Oct 2013 9:33am |
Thanks for the replies, chaps.
2nd Oct 2013 10:09am |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
I had a bad water leak that I traced to the armature gaskets - I was going to be fitting a towbar at some point so I bough the Westfalia armature and that came with the gaskets - I did try and search for a LR part number but couldnt get one for the gaskets.
2nd Oct 2013 1:35pm |
Plant Member Since: 01 Oct 2013 Location: Wirral Posts: 38 |
I don't suppose you still have these do you? I have just bought second hand Armature and need to source the gaskets. |
7th Oct 2013 8:31pm |
Yep sat on top of my tool box TDV8 Vogue SE 2009.
10th Oct 2013 7:35am |
