Home > Technical (L322) > Audio Cutting Out - DAB issues affecting RR/RRS/RRE + Disco
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Anybody else affected by this rubbish?
Reference SSM68017
Models Range Rover Sport / L320
Range Rover Evoque / L538
Discovery 4 / L319
Range Rover / L322
Range Rover Classic
Title Audio Loss/Crackle
Category Electrical
Last modified 05-Sep-2013 00:00:00
Symptom 207000 Entertainment Systems
Content
Issue:
Customer failure mode is an intermittent 1-2s loss of audio in any source, which then recovers but can happen multiple times.
The occurrences may vary depending on location and proximity to transmitters in the UK.
Cause:
The issue first occurred on Wednesday 28th August and corresponds with a change in the UK Broadcast for TV Electronic Programme Guide (EPG) feature.
This issue appears only to affect vehicles fitted with the Lear Hybrid TV module.
The broadcast causes the TV module to carry out a reset which results in a temporary loss in audio, irrespective of which audio function is being used e.g. (Radio, CD, etc).
Action:
As a temporary measure and with customer approval it is possible to mask this drop out by setting the TV region to USA. However, this does prevent the TV from operating but provides a quick although temporary fix until a more permanent resolution can be found.
1. No parts are to be changed in an attempt to resolve this issue.
2. Disable TV by selecting USA region from the touchscreen
3. It is essential to perform a successful shut down of thevehicle electrical system, by ensuring the ignition system is off and not used for a minimum of 5 minutes. This ensures the TV records this as a 'last good state' and that the new region is stored when the vehicle is powered on.
4. This is a temporary solution until permanent fix can be established. JLR will communicate this permanent fix as soon as possible.
Post #213279 30th Sep 2013 9:46pm
worth a read,
http://www.fullfatrr.com/forum/topic20459.html ... - .- -.
Post #213282 30th Sep 2013 9:48pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Its not only JLR. Wife had a rental BMW X5 recently and that did exactly the same thing!!
Post #213349 1st Oct 2013 9:52am
