Home > In Car Electronics (L322) > info display inop 2003 ffrr v8 vogue
hammiegt
Hi, not sure of the technical term for it, but the info stalk, button on end of indicator stalk, does nothing, my understanding is that it should, when pressed, display trip info under the milage, I know the panel is ok as it will display, lights on, key in ignition etc, and another strange thing its does is display the time every hour at 59mins to, ie 1159, 1259 etc etc, all trip functions work on the central display, but nothing on dash, have followed instructions in handbook but no joy, can live without it if its more than just swapping the stalk over, or does it have to be switched on with a diagnostics tool, any advice welcome
cheers hammie
Post #213082 29th Sep 2013 7:29pm
try pressing and holding in the button..it should bring up a selective menu on your screen..
...and can you update your car profile so we know what you have.. ... - .- -.
Post #213083 29th Sep 2013 7:33pm
hammiegt
have tried pressing and holding with no luck
Post #213108 29th Sep 2013 9:59pm
hammiegt
hopefully edited it now 2003 ffrr v8 vogue
Post #213109 29th Sep 2013 10:06pm
Have you got the timer/counter running?
See if you can turn that off on the main screen
and stan means the little FFRR next to flag not in your sig Thumbs Up .
Post #213110 29th Sep 2013 10:31pm
mjdronfield
The 59min display is a BMW thing and can be set to let you know it's 1 minute to the hour, so you can stop listening to a cd for eg and put the radio on so you don't miss the news headlines. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #213120 30th Sep 2013 6:57am
hammiegt
Not sure what you mean by the timer/counter running joe, had a quick look this morning, and the timer for the heater??? was set to on, on both times, but both times were the same, ie 1045 for both, I set them to off, but then a red light came on by the rh knob on the unit???, so have set them both back to on, not sure what the red light was for, with the 59mins to thing, is that something that has to be turned off by a dealer???
cheers hammie 2003 ffrr v8 vogue
Post #213175 30th Sep 2013 11:36am
