Home > Technical (L322) > Split Coolant hose-Help |
You can replace it yourself with some standard hose (cant remember the diameter off the top of my head) It's a bit of a pain to reach to the back of the engine, but with the pollen filter housing out of the way there is a fair bit more room.
30th Jun 2010 12:46am |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 |
I don't have a diagram, but the part is actually 18usd at the dealer... It's a small rubber/plastic coupler that adapts the BMW quick release coolant hose to I believe the heater core at the back of the engine. It is common for those to explode, the repair takes about 20 min, just about the easiest repair there is for the truck. You need to remove the engine cover, then the pollen filter... At that point if you look towards the back of the engine you'll see the exploded coolant hose... Remove a hose clamp and a quick release, it pops out, replace with new and you're good to button it back up. |
30th Jun 2010 12:50am |
dan originally helped me on this when mine exploded... How goes it Dan, other forum drives me nuts, it's ridiculous |
30th Jun 2010 12:51am |
Nappler Member Since: 09 Jun 2010 Location: Surrey Posts: 158 |
Thanks for the info guys, it was dropped off last night at a LR dealership, I didn't want to risk driving it at all while dropping coolant so will wait for their phone call.
30th Jun 2010 8:59am |
There's apparantly also a leak from a gasket near the o ring at the back or something?, not too sure as I've not looked at these engines in great detail yet, I've been quoted £280 all in parts and labour from a main dealer, does this seem excessive for a hose change? |
1st Jul 2010 1:32pm |
Really depends on what gasket and o-ring. PCV or coolant related? When they replaced the PCV hoses, did they do all of them? There are 4. Usually only the easy 2 get replaced. |
1st Jul 2010 2:12pm |
I haven't been on there in ageeeees, I tried to come back but I couldnt control my outbursts at ignorant twunts. Where as on here people see more willing to a, help them selves and b, use the search button. ViVa La FFRR.com! |
1st Jul 2010 2:18pm |
Was definatly coolant related, I can't remember what the guy said regarding the o ring but I'm 90% certain he said cylinder head, not sure on the PCV hoses as the invoice for when it was done is in the car at the moment,it's not the end of the world money wise, I just hate those items where 90% of the job is labour!. |
1st Jul 2010 5:02pm |
