Home > Maintenance & Mods (L322) > Brembo caliper threads |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1513 |
Thanks for this, really useful info.
28th Sep 2013 1:01pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8530 |
This happened to my front caliper. When i did my brakes i came to take the drivers side caliper off only to find that one of the bolts was tight as a tight thing. But the bolt did not crack off, it was tight all along the thread. I had a look when it was off an one of the threads was slightly mangled.....
28th Sep 2013 3:59pm |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 |
The brembo calipers are so easy to cross thread, it's obvious that foul play was the cause of the threading. When fitting my calipers I almost cross threaded them without even knowing.
28th Sep 2013 7:10pm |
I wondered about the helicoil but figured that the threads were much coarser than the standard, also wasn't sure about the availability of suitable HT bolts.
29th Sep 2013 9:10am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Two words for this..........................Copper Grease...... Simples
29th Sep 2013 9:55am |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
Right on! I am a big fan of copper grease. However, I am advised that the bolts are supposed to be tightened dry with some locktight and so I have resisted the temptation and made up for it elsewhere. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
29th Sep 2013 10:41am |
Locktight in an alloy calliper with a steel bolt is a good way to strip the thread my friend |
29th Sep 2013 11:03am |
That may explain the history as the stripped bolt that I removed had tell tale blue glue on it and it was the same dealer that recommended its use who had damaged the iriginal caliper.
29th Sep 2013 11:11am |
