Home > In Car Electronics (L322) > Problems with Bluetooth, Rear Camera, Audio etc in 2007 SC |
Mmmmmmmm well if you pulled the fuse and it worked for a bit, that indicates the problem is elsewhere in the system.
26th Sep 2013 3:05pm |
magnus911 Member Since: 15 Feb 2013 Location: Aspen, CO Posts: 5 |
Thanks for the response! Very detailed..
26th Sep 2013 3:24pm |
The diagnostic tool of choice here is the IID tool from Gap Diagnostics which seems very good value for money also thanks to very good support from Gap (they are in site sponsors)
26th Sep 2013 4:23pm |
Try bypassing the Bluetooth module as another test. |
26th Sep 2013 5:09pm |
Does that not include removing the fibre cables from their housing and connecting them together? 2007 Midnight Blue FFRR SC |
26th Sep 2013 5:19pm |
I believe you just take it out of the loop. |
26th Sep 2013 5:21pm |
When I unplug the MOST connector from the Nokia unit everything stops working... 2007 Midnight Blue FFRR SC |
26th Sep 2013 5:22pm |
There is a thread somewhere on how to reconnect without the Bluetooth unit in the loop.... |
26th Sep 2013 5:35pm |
You have to align the ends of the fibres "looking" at each other. Push the small blue tab out of the connector and pull the fibres out. You can use shrink sleeve to hold them together in alignment. Worked for me till I got my new module from Wiggs. MY 2010 5.0 SC Galway green and sand interior!!
26th Sep 2013 6:36pm |
Thanks, I'll give that a go. After a trip to the hardware store of course! 2007 Midnight Blue FFRR SC |
26th Sep 2013 9:08pm |
http://www.fullfatrr.com/forum/topic5270.html
26th Sep 2013 9:19pm |
