Home > Maintenance & Mods (L322) > does oil suction work on TDV8 |
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 |
dont know about the diesel...but used one on mine once,,,no problem
26th Sep 2013 6:36am |
You would need to measure what comes out to determine whether you manage a full sump drain or not. Some engines are not suitable for this method of draining, I know certain VW Passats caannot be done with vacuum pumps as it leaves a substantial amount of oil still in the sump |
26th Sep 2013 6:52am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
I can't see how this would get rid of the gunky stuff at the bottom of the sump that normal draining would flush away. I would have thought draining from the lowest point would always be preferable. Previously..
26th Sep 2013 7:31am |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
has anyone actually used one on TDV8?
26th Sep 2013 7:47am |
I often use a vacuum pump for draining oil and if you get the suction pipe correctly placed you can extract over 99% of the oil |
26th Sep 2013 8:18am |
which model would you recommend for TDV8?
26th Sep 2013 9:15am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 731 |
I use one on my TDV8 - The 1st time I used it I took the sump plug out to see how much oil was left in.
26th Sep 2013 11:09am |
which device did you use? |
26th Sep 2013 11:10am |
FYI doesnt the RR and other LR products have baffles in the sump that could cause issue with this?
26th Sep 2013 11:24am |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
Don't know about the TDV8, but earlier today I used a Sealey 6.5L vacuum pump on my TD6 and removed just under 8 litres of oil out of the engine. The oil I removed was a cheaper 5w40 synthetic I had previously put in to flush the engine prior to draining the rest via the sump plug, replacing the filter and putting in Castrol Edge.
26th Sep 2013 2:32pm |
how long does the sealey unit take to remove that much oil - did you warm the engine first? |
26th Sep 2013 2:34pm |
Mines a Sealey unit, it is a slow process I've never timed it - I just make sure that the engine is hot, set it away 1st and by the time that I've changed the oil and air filters it's ready to fill back up again.
26th Sep 2013 3:24pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
Might work on a 3.6, but definitely won't on a 4.4 TDV8 as it doesn't have a dip-stick.
26th Sep 2013 3:56pm |
A Sealey vacuum pump is still a great tool to use when you need to change just your oil between normal oil and filter service.
26th Sep 2013 4:51pm |
