Home > Maintenance & Mods (L322) > Too much oil? |
Drain it off as it's not good for the crankshaft or con rods slapping it when it's running FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
26th Sep 2013 7:46pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
to much can be as bad as having not enough..i'd drain some off to be safe. ... - .- -.
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
Thanks chaps, I'll drain some of it away.
26th Sep 2013 8:20pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
+1 as above... |
26th Sep 2013 8:22pm |
Had my Porsche serviced at the main dealer and they overfilled the oil, 2 weeks later oil was spewing out the crankshaft oil seal. Gearbox had to be removed sump dropped to fit a new seal, an expensive mistake for the main dealer |
26th Sep 2013 8:35pm |
A little overfill (few mm above the max cold mark) is not a problem but 1 to 1.5 liter is likely to cause some issues. MY 2010 5.0 SC Galway green and sand interior!!
26th Sep 2013 9:22pm |
