Home > Technical (L405) > Knocking noise
Page 1 of 6 123456>
Sb
England 2014 Range Rover Autobiography SDV8 Luxor
Knocking noise
Had my ffrr for a week now, sdv8 ab.
Love it but it had a strange knock from the front just like an Anti roll bar bush has worn.
In at the dealers, but they are none the wiser but agree it does it.
Any ideas?
Post #210905 18th Sep 2013 1:42pm
take a video of it when it happens and that will hopefully help the dealer find the problem..
or it could be something rolling about in the glovebox.. ... - .- -.
Post #210920 18th Sep 2013 2:39pm
Gremlin
United Kingdom 2014 Range Rover Autobiography 5.0 V8 Santorini Black
It is the new type terrain response 2. So my dealer told me
Post #210922 18th Sep 2013 2:40pm
Sb
It did it as we drove it away from showroom. They've accepted there is something wrong just don't know what to do!!!
The dealer can only do what LR tell them to but so far they don't know what it is!! Aaahhhh
Post #210954 18th Sep 2013 5:17pm
Gremlin
Nothing they can do So they say.
Post #210960 18th Sep 2013 5:41pm
Sb
None of the demonstrators that I drove did it, don't think I'll be accepting that response.
Post #210973 18th Sep 2013 7:01pm
Gremlin
Back it
Post #210974 18th Sep 2013 7:04pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Suggest that the dealer looks into active roll bar issues and engine mounts. Does the knock only occur when in a straight line? 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #211117 19th Sep 2013 4:44pm
Sb
My thought was active roll system too. Does it in straight line and when cornering, its more prominent on bumpy roads or when there is a sudden dip.Dealer says they have found the problem and should get car back tomorrow. However, we will see.
I wonder if it will come with an apology? It has put the dampeners ( no pun intended) on what should be a pleasurable experience.
Post #211130 19th Sep 2013 5:48pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
Hope you get it fixed soon, I'd be wanting a sweetener when its finally fixed. May be a free service Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #211572 22nd Sep 2013 6:36pm
Sb
Guess what? It was the active anti roll bar.
Picked it up on fri and seems to be ok. The dealer showed me the part they'd replaced. Apparently they are not allowed to open it up and investigate, but have to send it back. Land rover recon they have never had another one fail.
The service manager will send a report back to LR and we'll see what happens.
Post #211573 22nd Sep 2013 6:51pm
Nick Ground
Same old story then. Oddly mine had a new ARB but that was the only one too! Glad they have fixed it, enjoy. 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
Post #211669 23rd Sep 2013 12:19pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
recall on valve that causes air to get into the ARC Far to many gone...
Post #212370 26th Sep 2013 6:56am
RR4ever
United Kingdom 2015 Range Rover Autobiography SDV8 Mariana Black
ARB
Interesting thread. My new SDV8 ATB is going in next Friday for exactly the same grunt from front nearside. Luckily I'll now be able to tell them the solution! I did the same last week when I had the vibration from under the bonnet at 1300 rpm. Someone on the forum pointed out there was a JLR Bulletin on the issue "SSM63877 L405 V8 Transmission heat shield vibration 1400-1600 rpm" . That's the value of the forum! MY15.5 SDV8 4.4 A/B FFRR Mariana/Ivory
Ten other FFRR since 2002 either traded in or taken back by JLR
Post #214952 7th Oct 2013 4:41pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
How is it acceptable for a car of this expense to have problems already!
I'm really starting to think these things are thrown together, the quality department must be none existent.
My L322 is 7 years old and annoys me when it goes wrong. If it wasn't even a month old i'd go mental!
Post #215019 7th Oct 2013 8:36pm
Page 1 of 6 123456>
