Home > Technical (L405) > Knocking noise
Page 5 of 6 <123456>
lucky
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
thanks ! I will keep the faith !!
Post #259389 14th May 2014 4:11pm
Sb
England 2014 Range Rover Autobiography SDV8 Luxor
Guess what!! ITS BACK. AAAAHHHHH
Post #259971 17th May 2014 7:57pm
mcbs
range rover autobiography 5.0 sc 2014 knocking problem
Hi ,ive got a rr 2014 5.0 sc 1k miles and has had a knocking noise from front , a whining noise from engine which vibrates through steering wheel sounds like the viscose van type noise and as you turn a sharp slow corner you get a grinding noise from front,its in now and by the sounds of it it will come back the same,please tell me this will be ok as starting to think i dont want this car anymore,think the dearleship just took off the plastic,washed it,fuel and handed me the keys what happened to a proper check over on a 115k car.
heeelp before this goes bad
Post #262065 29th May 2014 10:05am
stuempf
Germany 2013 Range Rover Autobiography SDV8 Mariana Black
any updates to this ? did they fixed it ?
greetings stuempf Using your brain is useful. Sometimes.
Post #265258 13th Jun 2014 5:21pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
Yes the fix is i was told sell the car, i have done with my l494, now i do not hear it knocking , or the trim rattles Smile or the bits falling off Sad AND DO NOT HAVE TO GET IT BACK TO THE DEALER EVERY 4 WEEKS FOR SOFTWARE UPDATES AND RECALLS/SERVICE ACTIONS.
So anyone want an L405 AB 2000 miles on it ! only joking Far to many gone...
Post #266315 19th Jun 2014 8:58pm
Java Jungle
Monaco 2011 Range Rover Autobiography 4.4 V8 Nara Bronze
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up
JJ
Post #266400 20th Jun 2014 9:02am
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
my 4.4 Td My2011 had to go in to sort out tail gate issue.
got an 6 week old demo 4000miles 4.4 VSE as courtesy vehicle!!!!!
a really handsome car
the quality of the interior is great.
BUT
i know understand the suspension knock issues that L405 members are frustrated about. the ride is worse then my current FF.
the screen/infotainment system is badly thought out. i presume about 2 hrs was spent configuring it.
mercedes sorted this issue out in 2006.
i am looking carefully at these problems as i will HAVE to buy one of these in about a years time.
i would be very reluctant to change my L322 for a L405. as the ONLY improvement that has occurred is the aesthetics. Sad 2011 4.4 TdV8 Nara Bronze
Post #273001 27th Jul 2014 8:50am
Philip
The aesthetic appeal is one of the few things that hasn't improved.
Post #273028 27th Jul 2014 11:50am
tboner001
The car is miles apart from my older L322's and it is a totally different drive you cannot really even compare IMO.
The build issues etc will of course ala' LR be sorted by year 3-4 just like the L322 took 5 years to sort.
However on my ( wifey) L494 Sport i had enough that was dire with issues and its finish both outside and inside are not close to the L405 and of course it looks like a mix of the Ford and the Kia !!!!
Touch screen i think they went to far and should have kept a few more buttons the seats being the worst hmm i want warm 5 fingers later ! oh i want cold seats hmm now were was i !
My L405 is just fantastic in every respect and yes it took lots and lots of dealer visits to get all the silly things sorted and now even have a knock free car.
it's just a fantastic place to be behind the wheel .......... and you can even push on with it when you fancy it without being thrown out of the seat Wink Far to many gone...
Post #273180 28th Jul 2014 7:06am
RR2008HSE
^ I'm really pleased to hear it. I like to think progress is going forward and JLR isn't going to be in good shape if they're not making good cars.
I plan on keeping my L322 for a long time, but it's nice to know there's a modern equivalent waiting when it finally goes to that big scrapyard in the sky. (Mind you, I'll probably wait until depreciation means I can get a nice Supercharged Vogue SE for around £500.) Mr. Green
Post #273183 28th Jul 2014 7:18am
fairwx
2015 Range Rover Vogue SE SDV6 Luxor
in response to campaj1 - yes my TDV6 did (probably still does) have a knock, and the senior tech in Guy Salmon Bristol was stumped.
Anyway, they replaced it.
Post #273196 28th Jul 2014 8:30am
goldsax
replaced the car or suspension bits? 2011 4.4 TdV8 Nara Bronze
Post #273202 28th Jul 2014 8:52am
tboner001
tdv6 does not have active ARB or ARC !
presume in that case yours needed new struts which there is a recall notice on leaking struts Far to many gone...
Post #273247 28th Jul 2014 2:30pm
Tesh14
England 2013 Range Rover Vogue SDV8 Causeway Grey
I have a 2013 SDV8 vogue which has been in for the past three weeks at the dealership. After having two new ARC valve blocks fitted the knocking noise has stopped but now i have bad rubbing noise when i am turning right. I have been in dialogs with Customer service who have now told me that this is just a characteristic of the car, even though it was not there previous to their fix. Can anybody shed some light on what this noise maybe?
Post #284287 3rd Oct 2014 5:25pm
rocksteadyeddie
Does any one have the part number of the replacement valve block and (ideally) a 'how to' guide to change? Alternatively any idea how much the book labour time is? Many thanks
Post #562414 23rd Jul 2020 11:41am
