![]() | Home > Maintenance & Mods (L322) > How to Change Coolant Level Sensor |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Changing "Coolant Level" sensor in Coolant Tank
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35613 ![]() ![]() |
yee of little faith...already in the wiki.. ... - .- -.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
I would add that it is possible to do similar on the TDV8.
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 ![]() ![]() ![]() |
I changed my sensor, when I took it out no fluid came from the bottle yet I could see coolant in it, it was full to the correct level. When I drive the car over 60 mph I get the bong of the coolant level again. It seems bizarre, anyone have any thoughts before I remove the expansion tank. 2012 4.4TDV8 VSE
Methinks the "sight glass" inside the tank becomes occluded, hence the sensor cannot detect the level/concentration (all done with light?) Only resolution so far is a new tank |
What's strange is it did not leak any coolant when I took the sensor out the bottom! I think I will try a new tank. It's bloody annoying. My RR maybe used a little less, got myself a defender for summer.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Joe, i hate to state the obvious after the event but from memory (and it could be for the TDV8) a brand new coolant tank with sensor fitted is only a couple of quid more than the cost of just the sensor! |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
This 'sensor' is nothing more than 2 thin steel strips that normally are not touching each other to complete a (low power) electric circuit. They are encased in a glass tube for support and protection. When a magnet is close enough both pieces of steel become magnetised in the same phase and they attract each other to close the circuit [edited to invert wrong logic in original post |
ref: posts above from me and Cam Tech Craig
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 806 ![]() ![]() ![]() |
Reed switches are open circuit. Only when an external magnetic source is introduced does the circuit close causing the warning. When the float sinks due to low coolant, the magnet within becomes close enough to effect and close the switch. &t=106s 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Joe90,
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Thanks for all the contributions on here to this thread,Ill get onto this at the w/e, having to use RR DAILY JUST NOW DUE TO MY CAR BREAKING A ROAD SPRING ...MORE JOBS ! |
