Home > Maintenance & Mods (L322) > DPF Removal
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
DPF Removal
Has anyone here had any experience of retro-removing the DPF from a 3.6 or 4.4 TDV8 spec'd with it originally? Is it easily done and require any other modifications or changes to software?
Cam-Tech Craig, is this something you've done to any of your cars? MY11 Vogue 4.4 TDV8 - "African Queen"
Post #210811 17th Sep 2013 11:18pm
shalz
bump - no one? MY11 Vogue 4.4 TDV8 - "African Queen"
Post #210956 18th Sep 2013 4:25pm
Googsy
Have you tried one of the tuning companies? Normally this is something they provide Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #210962 18th Sep 2013 5:00pm
Removing the filter is the easy part, having the ECU sorted out is more difficult
Post #210975 18th Sep 2013 6:14pm
shalz
Thanks both - I'll raise with Cam-Tech Craig in the first instance otherwise look for a tuner. Reason I'm thinking of doing this is the quality of diesel is much lower in Kenya and the car will also be used mainly for short, urban journeys with very few long distance runs, so worried this will cause me issues in a place where LR is not very well represented for servicing. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #210993 18th Sep 2013 8:29pm
Don't remove the unit whatever you do!
Buy a used exhaust section from a breaker instead and knock the guts out of it Smile
You'll be thankful come MOT time(if you keep the car that long!) and if the DPF removal doesn't go the way you want it to you can easily refit and re-enable it Smile
IIRC deleting the DPF will result in slightly higher MPG and this is backed up from other cars i have heard of it being done on. PSA HDi units being the most common ones Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #211052 19th Sep 2013 10:15am
shalz
thanks kp. if this mod is done, i'd expect it to be a permanent one as there's no MOT in Kenya to worry about.
are there any other dangers (other than failing MOT) related to taking out the DPF? MY11 Vogue 4.4 TDV8 - "African Queen"
Post #211056 19th Sep 2013 10:28am
As long as it isn't driven gently all the time it should be fine as it should have a cleaner exhaust tract but could lead to more soot build in the exhaust tract if driven gently all the time as with the dpf it would enriches the fuel to get the exhaust very hot and burn it all off. A good blast on a hot engine every once in a while should do the trick Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #211064 19th Sep 2013 10:59am
shalz
thanks kp, glad to know..
juvenile i know, but on reading the word 'tract', couldn't help wondering "what if that post applied to the human body"... Rolling with laughter Rolling with laughter MY11 Vogue 4.4 TDV8 - "African Queen"
Post #211066 19th Sep 2013 11:02am
