![]() | Home > Wheels & Tyres > Nexens fitted |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
Well they are on the front, £100 each total inc fitting and balancing. One of the Pirellis changed was actually down to the canvas on the inner edge so I guess I had my money's worth from that bad boy. Initial short drive seemed fine with that new tyre feel you always get, at least one motorway drive this week so that should be a bit more informative.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35649 ![]() ![]() |
very good tyres nexens...my only reservation is the slightly softer sidewall which is easily damaged when off road and the visual look of the tyre being under inflated.... ... - .- -.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I had been looking into Nexen's too. I don't want to come in between any relationship the site sponsors have but if you are in the north west of england there is a firm doing a set of 4 inc fitting and balance for £395.00, and you can choose 255/50/20 or 275/45/20..... Is this where I put the car details and a bit about myself ?........ |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Where in the North West? Do they do tracking as well? Previous cars:
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 ![]() ![]() ![]() |
I recently had 4 Nexens fitted to mine. As Stan says they do feel a bit softer in the corners and i have noticed a bit more road noise than I was getting with the previous Conti's, apart from that they seem OK. Not been offroad with them yet though. |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2290 ![]() ![]() ![]() |
Same here, good tyre but they look like they are lacking air and are a little "soft" while cornering.
Given that my Pirellis were shot - these actually feel much more planted on the road. Even the guy at the tyre shop that did the fitting said "a tyre's a tyre" - such a philosopher |
As posted elsewhere, the SC took a fair old emergency thump up onto a kerb a few days ago. No visible damage to the nearly new Nexen Roadian but today I thought the affected tyre looked under inflated (no TPMS activation). Took it to the tyre machine tonight and just like the opposite tyre, it was at the correct pressure setting. Strange/ just an illusion?
I'm happy with mine but one is faulty due to manufacture defect. So hopefully replacing will fix my vibration through steering wheel |
they do look under inflated Ryan, its due to the softer more flexible sidewall .... ... - .- -.
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 ![]() ![]() |
Do Nexen make a winter tyre? Regards
this one??
thats the normal pattern Mark.. ... - .- -.
