Best to start with the easy ones.
Is there water going anywhere else ? If you operate the washer and open the top tailgate do you see water running down the side channels?
Any brown water? This would indicate the seals in the washer motor have gone (Like mine did, it's in the Wiki)
If you remove the top spoiler, you can remove the wiper arm and nozzles and blow them out with an air line (I took mine off yesterday as the wiper arm cap wasn't seated correctly and was spewing water just down the screen, all wrong)
There is a very cheap fix for a knackered seal (NKSC did it and has spare washers) otherwise it may be a new motor required, from a main dealer its about £140
http://www.fullfatrr.com/forum/topic884.html
http://www.fullfatrr.com/forum/topic9924.html
http://www.fullfatrr.com/wiki/Accessing_the_rear_wiper_assembly Discovery 4 HSE
