![]() | Home > Technical (L322) > 'Check Dipped Headlight Bulb' |
Mapmuppet Member Since: 03 Sep 2008 Location: Guildford Posts: 153 ![]() ![]() |
Guys, any ideas ?
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
First things first;
Thanks for the swift response, much appreciated.
If the bulb that was not working then works on the other side, then its not the bulb. I have no idea how much xenon bulbs cost but I doubt they are cheap. It could be an electrical gremlin or as the dealer says, the control box.
Problem Solved, having spent a couple of hours out in the cold it was a loose connection on the back of the casing. Have cleaned with WD40 and all is working now.
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
WD40 were would we be without it |
