![]() | Home > Wheels & Tyres > Correct tyre pressure...? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
Would probably agree with you, all the tyres on my previous RR's wear in the centre on std pressures and 80% of the time it's just me in it.
Last winter I ran 34 at the back and 31 at the front but inflate if high speed motorway... |
Inside my door it says 36 front and 42 rear for full occupancy thats what I run with. Mine is a 3.6 tdv8 2008 im surprised theres a difference as they are fundamentally the same car. Present :2008 TDV8 HSE
RXWRR Member Since: 30 Jul 2013 Location: Staffordshire Posts: 60 ![]() ![]() ![]() |
@ Gaz: forgive the naivety, but why inflate if on motorway? Wouldnt the pressure expand at speed I.e if you were to take a pressure reading whilst tyre is warm the psi reading would naturally be higher (unless riding on nitrogen filled tyres)?
@ Googsy: I could be wrong but I think that's the pressure with 5 adults + loaded to the max with luggage etc... At least that what mine says. Better to be irresponsible and right, than to be responsible and wrong.
Hope im wrong because its usually just me in the car so if 33 / 36 is possible without increased wear I will be happy as ride is a little hard. Present :2008 TDV8 HSE
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
just a slight diversion to the OP; but how accurate are the TPMS readings likely to be?
Right just been out in the dark to check and it appears I should have 33 in front and 36 in rear which I cant wait to do tomorrow |
@ Googsy: 33 front and 36 rear is rthe ecomended pressure with 4 adults in the vehicle. If its normally just youself, you may want to lower it a little, say 31/34...?
When I am going up North on the Motorway I normally have four in the car so inflate for that reason. High speed driving requires correct pressure while local driving is fine on slightly lower pressures. |
In the past I used to go a bit higher on tyre pressure as it was supposed to reduce fuel consumption. So max weight pressure plus 0.1 bar or 1.4504 psi.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i have also found that garage gauges are all different,. the best way is to keep a stick gauge in the car. the slide out type, and pump them up in the garage/your driveway and check on the separate gauge. -stick some dymo on it with pressures etc.
Just put 33 and 36 in this morning makes a great differnce car feels more comfy... Present :2008 TDV8 HSE
just put 31 & 34 in mine, what a difference 2psi makes and only 1 or 2 onboard! Will inflate up when car fully loaded though. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
