Home > Wheels & Tyres > Correct tyre pressure...? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3738 |
Would probably agree with you, all the tyres on my previous RR's wear in the centre on std pressures and 80% of the time it's just me in it.
4th Sep 2013 6:40pm |
Last winter I ran 34 at the back and 31 at the front but inflate if high speed motorway... |
4th Sep 2013 7:05pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Inside my door it says 36 front and 42 rear for full occupancy thats what I run with. Mine is a 3.6 tdv8 2008 im surprised theres a difference as they are fundamentally the same car. Present :2008 TDV8 HSE
4th Sep 2013 7:26pm |
RXWRR Member Since: 30 Jul 2013 Location: Staffordshire Posts: 60 |
@ Gaz: forgive the naivety, but why inflate if on motorway? Wouldnt the pressure expand at speed I.e if you were to take a pressure reading whilst tyre is warm the psi reading would naturally be higher (unless riding on nitrogen filled tyres)?
4th Sep 2013 7:28pm |
@ Googsy: I could be wrong but I think that's the pressure with 5 adults + loaded to the max with luggage etc... At least that what mine says. Better to be irresponsible and right, than to be responsible and wrong.
4th Sep 2013 7:33pm |
Hope im wrong because its usually just me in the car so if 33 / 36 is possible without increased wear I will be happy as ride is a little hard. Present :2008 TDV8 HSE
4th Sep 2013 7:40pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 456 |
just a slight diversion to the OP; but how accurate are the TPMS readings likely to be?
4th Sep 2013 8:23pm |
Right just been out in the dark to check and it appears I should have 33 in front and 36 in rear which I cant wait to do tomorrow Present :2008 TDV8 HSE
4th Sep 2013 9:24pm |
@ Googsy: 33 front and 36 rear is rthe ecomended pressure with 4 adults in the vehicle. If its normally just youself, you may want to lower it a little, say 31/34...?
5th Sep 2013 7:00am |
When I am going up North on the Motorway I normally have four in the car so inflate for that reason. High speed driving requires correct pressure while local driving is fine on slightly lower pressures. |
5th Sep 2013 7:10am |
In the past I used to go a bit higher on tyre pressure as it was supposed to reduce fuel consumption. So max weight pressure plus 0.1 bar or 1.4504 psi.
5th Sep 2013 7:20am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
i have also found that garage gauges are all different,. the best way is to keep a stick gauge in the car. the slide out type, and pump them up in the garage/your driveway and check on the separate gauge. -stick some dymo on it with pressures etc.
5th Sep 2013 9:07am |
Just put 33 and 36 in this morning makes a great differnce car feels more comfy... Present :2008 TDV8 HSE
5th Sep 2013 10:22am |
just put 31 & 34 in mine, what a difference 2psi makes and only 1 or 2 onboard! Will inflate up when car fully loaded though. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
5th Sep 2013 1:06pm |
