![]() | Home > Maintenance & Mods (L322) > Testbook needed to reset ABS after changing brake pipes ? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Rave says that if you disconnect any brake pipes at the ABS unit you need Testbook to reset / fix things
So what is the "brake modulator" ? Is it the block in the engine bay next to the diesel cooler rad with all the plasctic coated pipes going in and out of it? If so I will only be doing the pipes going from it to the wheels, so shouldn't need to worry?
(Yes I know it is a petrol engined one, only photo I could find at short notice) . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Never needed to use Testbook or anything else when I replaced my brake pipes last year |
If you disconnect any pipes from the modulator block there is the risk fluid will bleed out of it and let air in.
Thanks guys.
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
I had the engine light come on after replacing the calipers as there was still air in the system. |
Yes I run the new pipes into the modulator block and bled the system using easy-bleed without any faults showing up |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
I have also changed my brake pipes from the modulator, albeit only the fronts but did that and bled the old fashioned way with no issues.
That's all good news |
Are all the nuts. unions and connections 10mm / 3/16" pipe and are there any special connectors (am thinking of the banjo one at the rear end) ?
Well I have been getting all the pieces together, parts and tools for brake pipe swap.
Nice bit of kit, remember to put the nuts on the pipe before you flare it |
You know I am going to forget don't you |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1457 ![]() ![]() |
I think the reset of the abs is esssentially a case of firing the solenoids in the abs block so that they push fluid through them to purge the air out.
