![]() | Home > Technical (L322) > Seat memory module |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 218 ![]() ![]() ![]() |
Hi,
Fame Member Since: 01 Dec 2012 Location: Oliveira do Hospital Posts: 42 ![]() ![]() ![]() |
Do the mirrore( outside one 's only!) change to the correct position for each key?Also the steering wheel position, are these 3settings correct for each key? If these are all correct, the n the. Memory must be okay, and it's just the. Bulb gone? My Indie told me that I must be carefully to step out onto the r unning board and not slide out, which tends to pull the whole sw itch attachment away from the seat, and if this gets damaged, it's very expensive to replace.(I don't know if just one little module is there ) I'd hesitate to change anything there , because of a lamp problem . Range Rover Vogue TD6 2002
Yes mirrors are adjusted when I press the three memory preset buttons and steering column as well I think. Must do a more systematic test to check everything... 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Are all your keys synchronised for the vehicle? This may lead you to believe it's a memory fault , when it is not synchronised with the other keys. Range Rover Vogue TD6 2002
Yes, all three keys work. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35509 ![]() ![]() |
try disconnecting the battery for a while...it just might reset that ecu. ... - .- -.
