Home > Technical (L322) > BONG...suspension fault! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
battery ? ... - .- -.
29th Aug 2013 2:41pm |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
That's what I first thought Stan, so I charged battery up, seemed ok ,...until the next day.
29th Aug 2013 9:18pm |
you will need to do a drop test on the battery to see if its holding its charge..
30th Aug 2013 6:45am |
Cheers Stan
30th Aug 2013 7:43am |
a drop test involves putting a drain on the battery equivalent of all the lights on, the a/c on etc..the dealer should be able to that..
30th Aug 2013 7:48am |
Rotorboater Member Since: 26 May 2013 Location: UK Posts: 36 |
I used to get it a lot, changed air suspension pump (surprisingly not as expensive as I thought) and it stopped, not been a problem since. |
30th Aug 2013 8:46am |
elbitrevnoc Member Since: 17 Mar 2010 Location: Berkshire Posts: 150 |
For what it's worth, my view would be to get ot checked out ASAP. I've recently had exactly the same experience - i.e., the dreaded bong and 'Suspension Fault' message flashing up from time to time. As the car seemed to be driving ok, I didn't worry too much, but took it in to my guy at the end of the week.
31st Aug 2013 5:01pm |
Oh poop!!
31st Aug 2013 5:35pm |
If it makes you feel any better, I probably did 300+ miles in it with the message come up every now and then. I'll keep my fingers crossed for you! |
31st Aug 2013 5:44pm |
No problems, made it home without fault.
1st Sep 2013 7:04am |
jerrytlr Member Since: 02 Apr 2013 Location: France Posts: 66 |
Surely more likely to be an alternator issue than battery issue?
1st Sep 2013 10:34am |
Right....Indy had the car for over a week while I was back in the UK
12th Sep 2013 7:11am |
Just spoken to my guy again, he is now on about changing the valve block on the suspension, any thoughts?
12th Sep 2013 8:15am |
DavidC Member Since: 08 Oct 2012 Location: Beds Posts: 66 |
I had a very similar experience to yours, have you had codes read?
12th Sep 2013 10:05am |
