![]() | Home > Technical (L322) > BONG...suspension fault! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
battery ? ... - .- -.
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
That's what I first thought Stan, so I charged battery up, seemed ok ,...until the next day.
you will need to do a drop test on the battery to see if its holding its charge..
Cheers Stan
a drop test involves putting a drain on the battery equivalent of all the lights on, the a/c on etc..the dealer should be able to that..
Rotorboater Member Since: 26 May 2013 Location: UK Posts: 36 ![]() ![]() ![]() |
I used to get it a lot, changed air suspension pump (surprisingly not as expensive as I thought) and it stopped, not been a problem since. |
elbitrevnoc Member Since: 17 Mar 2010 Location: Berkshire Posts: 150 ![]() ![]() ![]() |
For what it's worth, my view would be to get ot checked out ASAP. I've recently had exactly the same experience - i.e., the dreaded bong and 'Suspension Fault' message flashing up from time to time. As the car seemed to be driving ok, I didn't worry too much, but took it in to my guy at the end of the week.
Oh poop!!
If it makes you feel any better, I probably did 300+ miles in it with the message come up every now and then. I'll keep my fingers crossed for you! |
No problems, made it home without fault.
jerrytlr Member Since: 02 Apr 2013 Location: France Posts: 66 ![]() ![]() ![]() |
Surely more likely to be an alternator issue than battery issue?
Right....Indy had the car for over a week while I was back in the UK
Just spoken to my guy again, he is now on about changing the valve block on the suspension, any thoughts?
DavidC Member Since: 08 Oct 2012 Location: Beds Posts: 66 ![]() ![]() ![]() |
I had a very similar experience to yours, have you had codes read?
