![]() | Home > For Sale & Wanted > [Wanted] Good (must be good!) LT95 Gearbox |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Have u tried landyzone.co.uk? |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
I had a look at the classifieds but I haven't put a Wanted on there yet - will do tho, thanks |
Try motorhog.co.uk |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
What about a lt77 ? |
There are differences in where things end up IIRC |
Quite a lot of differences I think, and as the Defender has already been hacked to fit the 95 and all the controls, it's going to be easiest to replace like-for-like. It's enough aggro just changing the box (and massively unrewarding when the new box you fit is ten times worse than the one you took out!) so I'm trying to minimise the pain!
IS getting it rebilt not economical or getting the parts and DIYing it at all? Surely it cant be that bad as long as you have a nice big work bench and its all clean? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
From what I can find, Will, rebuild opportunities are few and far between, and also of questionable quality (eg a steam-cleaned box = a fully-overhauled unit!). In addition, if you fit genuine parts, they're REALLY expensive (eg �100+ for the input shaft bearing alone, although you can get aftermarket ones for �20-ish).
It would be a lot better with a r380 and a lot more of them out there so easier to get a good one |
If I went that route Brian, off the top of my head I would need:
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
An R380 is by far the nicest 'box out there, but that'll mean transmission tunnel changes and bellhousing changes. Not sure if there's an adaptor to fit the R380 in place of the LT95, but it may be worth looking on Ashcroft's site. But then you could always end up with a pup of an R380 as well...
Try and give Ashcroft a ring and see if they have any instock. If not then maybe ask them if they would refurbish one of your box's and how much and if they would be interested in buying your other one as im guessing you swapped it out you kept the old box as well?
Ashcroft can make you a r380 with a short bellhousing so the gearbox sits in a better place. Lots of the racers have this set up |
