![]() | Home > Maintenance & Mods (L322) > Uprated Pully for a SC Vogue |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
there's a couple of threads on here about fitting the pulley if you search
Ipslore Member Since: 21 Apr 2013 Location: St Helier Posts: 39 ![]() ![]() ![]() |
I think this is the thread from AllSeeingPie. Fair amount of info on the Jaguar site as well.
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Yup, I got the PowerHouse 6% one and they fitted it without the need to modify the supercharger snout. The 10% pulley is a sod to fit on the FFRR and needs the supercharger to be removed. I've also had colder spark plugs, Eurocharged remap, custom intake tube, 200cell cats and I'm on my second custom exhaust (post coming soon).
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
slightly OT but 'colder sparks plugs' ?...does it run/idle better with these... ... - .- -.
The spark plugs let the ecu/map advance the timing allowing you to burn fuel longer. This means more fuel can go in and therefore more power is generated. It hasn't adversely affected the idle/running but I couldn't say they make it smoother. LR use iridium plugs for the SC anyway so it didn't start out with a bad set to begin with. I have noticed a lot more low end pickup and torque from the mods. In winter it had a few moments where it idled a bit rough on startup, but that cleared after about 30 seconds and it was -12 at the time. |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I've also had mine done together with a remap and an estimated 460bhp, according to the Jaguar specialist who did the work.
460? that is interesting. who did this work for you? I'll get in touch with them |
I'm not sure about 460 from a 6% pulley and map. If think it'd be in the 445 area at best. Not that it matters because its the gearbox software that's most limiting. My remap had the redline moved to 6750 but the gearbox changes at 6300 max. |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
please give more information on these "colder spark plugs" - what brand and specifications - how would i know whether it is colder, hotter or the same as the current spark plugs? thanks |
From NGK's site. Basically what ASP's post above is saying is that the cooler running plugs don't induce glow-ignition or pre-ignition under intense heat loads which therefore allows more fuel to be forced in before the increased volatility of the pressurised fuel/air mixture becomes a problem.
