![]() | Home > In Car Electronics (L322) > IPOD / Iphone.... again..... |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Do you have RSE with the Aux inputs in the rear?
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 958 ![]() ![]() ![]() |
nope mate, don't i'm afraid hence wondering about the back of the nav / glovebox etc |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Yes there is a unit which fits behind the dash and gives ipod connectivity and control via steering wheel.
DTaylor Member Since: 15 May 2013 Location: Manchester Posts: 163 ![]() ![]() ![]() |
if its the m.o.s.t system they have to be made by land rover and are over £400, I ended up paying £20 and getting a decent fm transmitter
just looked at the old thread and dan said £357 if there was 5 of us buying...... but none of us ever took him up on it.....do we know how we fit it though? is it just a case of putting the lead into the back?
I think it plugs into the cd changer cable. And then lets you reconnect the changer |
Fitting the ipod kit is a bit of a faf, ends off the dash, top off then it seems to be plug and play. From memory, having read the instructions somewhere, it involves unplugging the cd changer Plugging the unit into the back of the head unit and then connecting the changer to the unit itself.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
If it's based on the dension 500 type adaptor it plugs into the cd changer input and emulates the cd changer. They are a very good unit though and usually allow full ipod connection. Is this where I put the car details and a bit about myself ?........ |
From what I remember of previous threads the Land Rover ACM is based on the Dension unit as it is made by them but a Dension 500 unit will not work with the FullFats MOST system . 2008 MY Supercharged
must be the DENSION GATEWAY then as that will synch up with the LR systems Is this where I put the car details and a bit about myself ?........ |
Sorry , to be clear there Dension Gateway is compatible with non touch screen cars but the OP has a touch screen and its that system it can't work with . 2008 MY Supercharged
ok, I'll need to check and get the correct one then...my local ICE shop are good and I have dealt with them for years - hopefully there will be a sub £500 solution Is this where I put the car details and a bit about myself ?........ |
i will ask dan to see what the current price is etc...... taking the dash and dash end off is actually pretty easy i reckon its an hours job all in.... |
plumajp Member Since: 18 Jul 2013 Location: bridgend south wales Posts: 73 ![]() ![]() ![]() |
guys will the denison gateway fit non touch screens? has anyone got one that can confirm?
