Home > Maintenance & Mods (L322) > Illuminated sill plates. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
KFP, be careful that's not a permanent live otherwise your battery will go dead very quick... ... - .- -.
20th Aug 2013 2:28pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Have you had the door open with the car running yet? As some power supplies will make them flash whilst the engine runs... Takes 30 secs though to get flashing... |
20th Aug 2013 6:14pm |
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 222 |
Yeah had the engine running and all seems fine but I'll keep the doors open for longer tomorrow just to check all is good.
20th Aug 2013 6:48pm |
Touch wood, everything seems to be working ok. I quite like the green glow. |
21st Aug 2013 1:09am |
21st Aug 2013 1:10am |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 |
Got mine fitted today. Piece of cake with clear instructions and simple install with a blanked off wiring connection for each side already in the car. A couple of minutes to do each side with a very classy end result. Well pleased 4.4 TDV8 Vogue Baltic Blue MY11 |
21st Aug 2013 10:01pm |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Well if these are any good they must be a bargain, anyone know?
22nd Aug 2013 6:45am |
i saw those as well Paul, but are they not a different shape.. ... - .- -.
22nd Aug 2013 7:46am |
Yes they haven't got the cut out shape of the others that's why I was wondering if anyone has knowledge of them, they sound too cheap on reflection, usually you only get what you pay for. Agueroooooooooo. 93-20
22nd Aug 2013 8:11am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
I think they are scuff plates that stick on the exposed area of painted cill when you open the doors. The original plates will stay in place alongside. |
22nd Aug 2013 8:34am |
Looks as though you are right about the scuff plates and if you are it seems some drilling of the sill would be necessary and then perhaps some fiddling try to sort out the wiring. I'll leave these alone i think. Agueroooooooooo. 93-20
22nd Aug 2013 11:01am |
They might look ok. If they fit on the outset sill, I presume that they'll just stick on with some foam sticky pads. You might have a small section of visibly wiping where it gets fed from the sill into the cabin but you could minimise it by running it along/through the rubber draft excluder thing that goes around the door aperture. |
22nd Aug 2013 9:45pm |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
9th Sep 2013 9:11am |
i think they look pretty good but i wouldn't pay £250/300 as seen on ebay ..
9th Sep 2013 11:15am |
