Home > Maintenance & Mods (L322) > Illuminated sill plates.
KFP, be careful that's not a permanent live otherwise your battery will go dead very quick... ... - .- -.
Post #204951 20th Aug 2013 2:28pm
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
Have no fear oh wise one, I just went out and checked that both lights go out along with the interior lights.
Cheers for reminding me though...
Post #204986 20th Aug 2013 6:11pm
Have you had the door open with the car running yet? As some power supplies will make them flash whilst the engine runs... Takes 30 secs though to get flashing... Thumbs Up
Post #204988 20th Aug 2013 6:14pm
kungfupanda
Yeah had the engine running and all seems fine but I'll keep the doors open for longer tomorrow just to check all is good.
Seriously though, thanks for all the tips guys!
Post #204995 20th Aug 2013 6:48pm
kungfupanda
Touch wood, everything seems to be working ok. I quite like the green glow.
Post #205025 21st Aug 2013 1:09am
kungfupanda
Post #205026 21st Aug 2013 1:10am
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Got mine fitted today. Piece of cake with clear instructions and simple install with a blanked off wiring connection for each side already in the car. A couple of minutes to do each side with a very classy end result. Well pleased Thumbs Up 4.4 TDV8 Vogue Baltic Blue MY11
Post #205175 21st Aug 2013 10:01pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Well if these are any good they must be a bargain, anyone know?
eBay Item No. 151104947002 Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #205198 22nd Aug 2013 6:45am
i saw those as well Paul, but are they not a different shape.. ... - .- -.
Post #205206 22nd Aug 2013 7:46am
Pfazz
Yes they haven't got the cut out shape of the others that's why I was wondering if anyone has knowledge of them, they sound too cheap on reflection, usually you only get what you pay for. Agueroooooooooo. 93-20
Post #205208 22nd Aug 2013 8:11am
I think they are scuff plates that stick on the exposed area of painted cill when you open the doors. The original plates will stay in place alongside.
Post #205214 22nd Aug 2013 8:34am
Pfazz
Looks as though you are right about the scuff plates and if you are it seems some drilling of the sill would be necessary and then perhaps some fiddling try to sort out the wiring. I'll leave these alone i think. Agueroooooooooo. 93-20
Post #205228 22nd Aug 2013 11:01am
kungfupanda
They might look ok. If they fit on the outset sill, I presume that they'll just stick on with some foam sticky pads. You might have a small section of visibly wiping where it gets fed from the sill into the cabin but you could minimise it by running it along/through the rubber draft excluder thing that goes around the door aperture.
Post #205309 22nd Aug 2013 9:45pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Not sure I would have bought them but they were on the car when I got it.
Must rate as the most useless accessory.
Ian
Post #209013 9th Sep 2013 9:11am
i think they look pretty good but i wouldn't pay £250/300 as seen on ebay ..
the bit i have a problem with is scuffing on the lower sill ..i've seen some stick on sills for about £30 on ebay which look good.. ... - .- -.
Post #209033 9th Sep 2013 11:15am
