Home > Maintenance & Mods (L322) > Arm Rest Removal |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3783 |
I've asked this before but can't remember what the answer was. As you can see the armrest trim needs repositioning and sticking back in place, whilst not a big task it would be made possible/much easier if I could remove the armrest but I can't see how.
18th Aug 2013 2:04pm |
Maybe this might help Geoff ….
18th Aug 2013 4:45pm |
Thanks Mick, I think it does, not that clear, but it looks like remove tension straps from underneath then two torx from under the lower seat back panel, remove that panel and then I can get at the allen nut holding the arm on. Then Roberts your mothers brother.
18th Aug 2013 6:28pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Geoff, you'll need to remove the seat And heads up, they aren't that light And then we are assuming that they go together the same as the BMW seats...... might be inclined to wait to hear from some one who's done this with the Ford seats..... they could go together differently Yesterday I couldn't spell Engineer... Today I are one!
26th Sep 2016 4:04pm |
Hold up...... that arm rest comes off first so the allen bolt must be get-at-able without seat removal, might need to jamb some fingers or something to get the clearance to remove the bolt...... Yesterday I couldn't spell Engineer... Today I are one!
26th Sep 2016 4:09pm |
georgedb Member Since: 12 Apr 2015 Location: Gauteng Posts: 82 |
very tight (between backrest and armrest) |
26th Sep 2016 4:35pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Seat out is a possibility but you might be able to undo the the seat and prop it up to get good enough access . I took the seats out when I replace the drivers back Peltier cell and regretted it so the next time when I changed my BPM I just reclined the back a bit so I could lift it higher and propped it up then disconnected the battery to stop any airbag faults and did the work . 2008 MY Supercharged
27th Sep 2016 12:52am |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
I agree, that's a two bottle job... |
27th Sep 2016 9:14am |
