Home > Technical (L322) > Towbar wiring- bulb check sequence? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8517 |
That is a relay specific thing, if you are changing i would recommend pilling all the old wiring oit and fitting gen lr plug and play kit. Ok you wont get the flashing light show at the start bit it will talk to the canbus and you will get the error on the dash should something fail.
14th Aug 2013 9:03pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16286 |
14th Aug 2013 9:24pm |
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 |
Would love to go genuine, but Dan says its no longer available.... But I found the unit I currently have, from these people. Lo bading, but same size and shape, and the unit behaves as per the description here.
15th Aug 2013 5:36pm |
Would love to go genuine, but Dan says its no longer available.... But I found the unit I currently have, from these people. No badging, but same size and shape, and the unit behaves as per the description here.
15th Aug 2013 5:37pm |
