Home > Technical (L322) > Loud pop opening driver's door too fast
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
I let my driver's door open a bit too fast after parking yesterday and I heard a very loud plastic-sounding pop when the door reached its stop position. Can't see any visible damage. All electrics, window and mirror still work ok and the door still opens, closes and locks fine. Anyone heard the same sound before and can tell me if/what I've broken? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #203495 11th Aug 2013 6:43pm
Check you havent popped the door stay out or snapped it, if that ok youi may have escaped serious damage. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #203498 11th Aug 2013 6:58pm
modbarra
Scotland 2019 Range Rover Autobiography 5.0 V8 Loire Blue
Check the lower panel on the wing, had that happen on previous ffrr
Post #203527 11th Aug 2013 9:15pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Yep, as per nothernMJ , I got a loud popping noise on my door as it reached its maximum open extent and on checking , found it to be the star headed bolt that holds the door stay to the bodywork. I opened the door to its max, then moved it backward and forward slowly and could see the stay mount moving beneath the bolt. Tightened bolt up (obviously had worked loose slightly over the years) and cured problem. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #203593 12th Aug 2013 11:18am
FrankRizzo
Checked door stop today and it seems fine. Star-headed bolt on door stop mount seems tight although I don't have a tool to tighten it (where do you get those?) and there's no movement when I move the door in and out. Maybe I've gotten away with it but I can't see what could have made such a loud pop... 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #204590 17th Aug 2013 11:33pm
RRVSE
Ah , if it's not the door strap, I'm not sure , although you could check the outside lower part of the door (with the plastic panel on it) isn't catching the front lower wing section (plastic panel beneath the side grilles), as that may also create a plastic type noise. I got my socket set from a chain of shops called 'Clas Ohlson' (Swedish in origin) , don't know if you have them in Germany (can't find a website for 'de'). These are the ones I bought...
http://www.clasohlson.com/uk/Cocraft-Socket-Set/40-8319 Steve
Post #204591 17th Aug 2013 11:52pm
FrankRizzo
Lower panel seems ok, too, so I think all's well. Thanks for the link, picked up a set that will probs come in handy in the future. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #205544 24th Aug 2013 10:39pm
RRVSE
Fair enough. If I think of anything else I'll let you know, just have to hope it was a glitch that has cured itself. Steve
Post #205548 24th Aug 2013 11:16pm
