![]() | Home > Maintenance & Mods (L322) > Solved ? What could be leaking in these pictures? |
See 11.09.13 Update:
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1369 ![]() ![]() |
probably residual spillage from when the rad was changed , just clean the drip trays and monitor for any losses
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Suggest you remove all the undertrays that are below engine and gearbox components, this will help to direct you to any ongoing leak. Get an old sheet or similar that you can put underneath in the same place each time you park up.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
The last pic that you posted is your gearbox sump......
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
As said above, some common sense DIY will help here.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Antifreeze should be pink sir ![]() |
HAH! You're very right Craig. What a dimwit. Too much red wine again. I should stay off the forum after a few glasses, makes me look more of an idiot! |
Green could be refrigerant oil. |
Just so long as the wine's not green ![]() ![]() ![]() |
Thanks for all of the replies.
Nothing should be dripping out the bottom of the car except water from the air con. |
Thanks Joe... For many weeks people have said the leak I've referred to might well be air con water but as mentioned, this stuff is staining the floor and whilst I've had cars before that discharge AC water on the floor for fun, its never stained before which this leak does. Your other obs are noted with thanks as well |
Old PAS fluid can look a golden colour. Any steering groans or stiffness at low speed? Discovery 4 HSE
Adam, yes... From day one I've said the steering isn't right at low speed, despite them replacing the Servotronic valve. No groans I can recall but stiffness is a good way to describe it. I've previously referred to it as a pulsating judder/vibration/ bobble etc during low speed turning manoeuvres.
