Home > General > Diesel or Petrol Reliability - Your views appreciate
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Fellow Forumees
Simple question, is a diesel more reliable than a petrol? Reason for the thread is that I had a 2001 Disco 2 V8 for 85,000 miles with no issues apart from usual servicing, have had a 2004 TD6 for similar mileage and no end of issues, never had a FFRR Petrol but am erring toward one, is it just an anomaly or does anyone believe the petrols are more reliable or Disco 2s were better built, Thanks Very Happy 2013 L405 Autobiography Baltic Blue
2007 L322 Vogue Buckingham Blue
Post #203323 10th Aug 2013 8:43pm
i would have thought that with the correct maintenance and tlc both would be equally reliable.. ... - .- -.
Post #203324 10th Aug 2013 8:47pm
Rosco
Stan, good point however both cars had maintenance done as and when they needed it at main dealers in accordance with guidelines etc. I know it is probably an unusual one as all cars are built differently and someone with 2001 Disco 2 V8 could have had a nightmare and a TD6 could be a dream. However I want a new FFRR and seriously considering an SC, trying to convince myself Very Happy 2013 L405 Autobiography Baltic Blue
Post #203326 10th Aug 2013 8:54pm
Years and years ago diesels were more reliable. They didn't have the very unreliable ignition systems of petrol cars of those days - just a mechanical injection system.
Spin on to the present and diesels are very complex and particulate filters are proving to be an industry wide problem.
Petrols look quite simple in comparison.
Having said that, my TD6 has been ok apart from the injectors.
Post #203330 10th Aug 2013 9:11pm
i was in the same situation and decided on the s/c and i'm very happy i did. ... - .- -.
Post #203331 10th Aug 2013 9:17pm
Rosco
Kurt, that is my issue, years of petrols with no real issues now last 8 years with diesels!! yes slightly less in fuel costs however, I now believe false economy, backed up by maintenance costs, still have my old 4.2 Audi S6 that costs me nothing bar servicing and fuel, want an SC so trying to convince myself Very Happy 2013 L405 Autobiography Baltic Blue
Post #203334 10th Aug 2013 9:19pm
Benfelrr
United Kingdom 2007 Range Rover Vogue TDV8 Tonga Green
have had 4 range rovers. 3 petrol 1 diesel All about the same reliability. Engine wise to date, trouble with none of them, petrol or diesel. Touches many trees quickly!
Post #203341 10th Aug 2013 10:22pm
The problem is mainly with service intervals being massively extended. Diesels are often thought of as super robust low maint units and they aren't, they still need looking after, especially with the turbos and tight tolerances of modern ones. Servicing a car early is the best way to make it last longer and so many ignore this and let it stretch on to 20k or so before a basic service Sad
The FF engines have the advantage of using a timing chain compared to a lot of cars so thats one headache sorted but still all fluids should be flushed every 3years and often aren't.
Any car can be poorly maintained and be a money pit to future owners and buying on condition and care from previous owners is the best you can do Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #203342 10th Aug 2013 10:27pm
Rosco
Stan, did you have a diesel before? I want an SC. just trying to justify it, hope you understand Very Happy My S6 put me off petrol, even after my D2 V8, i am convincing myself it was the car!!! 2013 L405 Autobiography Baltic Blue
Post #203345 10th Aug 2013 10:33pm
yes i did Rosco, it was a td6 and a fine vehicle but it was a tractor and although i did some mods to it like blanking the egr valve i did not get much more mpg around town as i do now with the s/c and my s/c is so quiet... ... - .- -.
Post #203363 11th Aug 2013 6:46am
They are quiet aren't they ,,,,,,,, until Very Happy
The AJV8 in it's different guises dose seem to have a good reputation for reliability all I have herd about is one or two cam chain tensioner issues on the NA engine .
It does seem fairly common for people to move on from a TD6 and think to them selves " I must have another FullFat "
and go and get a Supercharged . 2008 MY Supercharged
Post #203387 11th Aug 2013 8:16am
Dolphinboy
Like Stan, my first FFRR was a TD6. Whilst it was fault-free, and a great reliable car, my petrol (BMW 4.4 VCool is far superior, both in performance and sound! Also, both BMW units are fairly bomb-proof. I believe petrol has the edge in terms of lower costs when things do go wrong!
Post #203389 11th Aug 2013 8:18am
Vogue
They put Diesel engines in trucks tractors and PSV's for a reason, reliability and economy over many miles. That said I have both petrol and diesel RR's and as long as they are serviced and looked after there seems to be very little in reliability between the two. What does make a difference is people messing about with cheap tuning boxes, cheap maps and generally flucking an engine up for the next owner.
If you can find a good vehicle with known history and know its not been tinkered with all should be well. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #203408 11th Aug 2013 10:43am
Now at 140k with TD6 (says something in its self), patchy history up to 86K, then with me for remainder. Only issue with engine in all that time was the oil particulate filter clogging up, which only really came about because it is not listed as serviceable in Rave, so I didn't know it was there! This forum sorted that out!
So tractorish yes, but reliable with it. That said, other than the peripherals on the petrol engines (PCV hoses in particular) reliability of engines of both types seems on a par (original TD6 + 4.4 V8 ) based upon what I pick up on the forum, but this relies on regular servicing and attention.
As far as the SC goes, all these boy racers on here will have thrashed the t*ts off them Twisted Evil .
Post #203417 11th Aug 2013 12:18pm
i wondered where my t*ts had gone... off to the dealers to get new ones... Mr. Green ... - .- -.
Post #203422 11th Aug 2013 12:49pm
