Home > Maintenance & Mods (L322) > lots of black sooty smoke
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
just done a fuel,air and crank case filter change now getting a smoke screen oo7 would be proud of.....
can any one shed some light pls
52 plate td6 have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #203315 10th Aug 2013 8:11pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Assuming it wasn’t smoking before you did the filters I would check the crankcase breather again. If you just put a new foam filter into the old hosing it’s possible the valve in the crankcase breather is jammed, I would get a new casing and a vortex filter which doesn’t gum up.............you can do a search on here for the vortex option
Post #203325 10th Aug 2013 8:48pm
ahebron
New Zealand
My car did this all of a sudden. What state is your inlet manifold in. Mine had about 5mm build up of soot and after I cleaned it the following black cloud disappeared. Others have had this issue.
http://www.fullfatrr.com/forum/topic10004.html
Adrian VW Amarok 2014 Highline auto
Post #203401 11th Aug 2013 10:05am
trainmanone
think ive sorted it ,cleaned out the crank case breather valve and put another new air filter on ,only blows a bit of smoke from standing start so happy with that . what's the best oil to use as going to do an oil change next week. have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #203599 12th Aug 2013 12:26pm
