Home > Technical (L322) > Balls!
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Balls!
Anyone know how tight the ball joint nut should be? I've replaced the upper suspension arm (the one with a separate all joint) and the crappy pram sound seemed a bit worse if anything Shocked
I googled it and found some bulletins that said it needed to be 48nm plus a quarter turn (as opposed to my current idea of nipped up). I've just tried it at 48nm and really don't want to snap anything. I've turned it at least a full turn and it still hasn't clicked, and that was doing the turning with my foot! I'm going to try it tomorrow (blocked in by the wife).
Anyone know the number/ done it themselves? I don't want to hear a loud snapping noise! My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #202499 5th Aug 2013 5:56pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Are you sure it's not just turning inside the joint? I always thought it was annoying that you had to use a ring spanner and an allen key in the centre- how are you supposed to use a torque wrench?
I'm watching your results with interest as I am planning to do upper and lower arms with all ball joints soon, thanks for parts supplied by Dan @Duckworths.
Post #202515 5th Aug 2013 7:36pm
Should nt need to be mega tight. 48nm is pretty "nipped up'
Wheels etc are about 140nm for comparison, even that isnt standing on it teritory. There is nothing that can't be fixed with a hammer😜😜
Post #202519 5th Aug 2013 7:48pm
hoppy_70
Maybe I need an air ratchet.... I hadn't even thought it might be turning. Hopefully not as its tapered AND has the car weight on it. I'll update tomorrow if its worked. The manual says it should be 60nm. I'll try that if it doesn't work. My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #202529 5th Aug 2013 8:34pm
If you snap it when tightening it up then you won't need to worry about it napping whilst driving. Whistle
Post #202530 5th Aug 2013 8:36pm
hoppy_70
I hope it doesn't snap! It isn't an expensive part but doesn't look like its going to come out without some sort of special tool. I think it's pressed into the hub (I only replaced the arm and bush) My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #202531 5th Aug 2013 8:38pm
Stephen.125
Yeah, fair point the full weight of the car on the taper should hold it pretty snug. Hope you get it sorted!
Post #202549 5th Aug 2013 9:22pm
