![]() | Home > Camping, Caravanning and Holidays > proper caravan. |
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 ![]() ![]() ![]() |
Can I ask how you went about getting the upgrade to your caravans weight plate?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8678 ![]() ![]() ![]() |
its all based on the MTPLM of your van and the axle weights that are stamped onto the axle crossmember plates.
Mark6r Member Since: 25 Jun 2012 Location: South Lanarkshire Posts: 90 ![]() ![]() ![]() |
If you go to the local sterling dealer they can order you a weight upgrade plate from swift for £50 going to order one for our sterling Eccles SE trekker van in the next few weeks after seeing how much gear we took for 2 weeks away so any extra payload would be a bonus.
generally it is fairly easy to do as the ALKO chassis are normaly rated higher than the MTPLM of the van as in the UK manufacturers have an obsession with lightness, they will then offer it as a chargeable service or free at order.
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 ![]() ![]() ![]() |
Nice outfit! |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Suppose weight is the downside to a slide out.....
