Home > Technical (L322) > Removal/access to windscreen washer reservoir ?
Mark_001
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Hello,
My windscreen washer reservoir is leaking badly and I need to investigate. Can anyone advise the best way to access it/remove it ? - top down removing airfilter housing and LH headlight or via LH wheel arch (removing the plastic cover) ?
Any advice much appreciated.
Thanks
Mark
Post #201364 29th Jul 2013 11:38am
Best way to access it is to remove the front bumper, sounds like a big job but it really isn't, it's held on by about 10 screws. Discovery 4 HSE
Post #201365 29th Jul 2013 11:44am
Mark_001
Thanks a lot Martin
Will investigate tonight !
Mark
Post #201371 29th Jul 2013 12:21pm
Martin? Discovery 4 HSE
Post #201380 29th Jul 2013 2:36pm
Here's a thread with a how to
http://www.fullfatrr.com/forum/topic14759.html?highlight=bumper Discovery 4 HSE
Post #201381 29th Jul 2013 2:39pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
I took the LR workshop manual route of removing the passenger front side wheel arch liner - which was easy! The two bolts which hold the washer bottle in place face the wheel anyway.
I found it difficult to remove the washer water filler hose however!
Post #201963 1st Aug 2013 9:55pm
