Home > Maintenance & Mods (L322) > Upper Tailgate Corrosion - Repaint or Replace?
Googsy
Thats what I said to my first girlfriend Laughing Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #200915 26th Jul 2013 9:07am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Just had mine done as the long winter took it's toll and the small pin heads of rust on the edge started to spread up the sides.
I am going to fill with waxol sprayed in while its warm so hope it should last while I have the car.
For info
Tailgate repair,repaint
Bumber repair, repaint (Some T**t in a disco hit it and drove off on a car park only had it a week!)
Door satin black surround, stone chip had let water under paint leaving what can only be described as a spiders web.
Repair to small dent in "C" Pillar trim again satin black looks like someone threw a stick at car.
All in £260 if I delt with the Letters.
Thought that was good price? Mine was a blue one! Smile
Post #200930 26th Jul 2013 10:43am
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
supershuttle wrote:
I've got e related question having just had mine done, not under warranty ( just outside the 6 years so I didn't even ask ) but what can be done to prevent a recurrence. I suppose what I really mean is where does the water get in and what can be done to prevent or reduce the ingress - the drain holes must be there for a reason?
My warranty repairer said that they are instructed by LR to spray waxoil inside the bottom of the door to stop the same happening again. I removed my door trim to check and mine has been done. 4.4 TDV8 Vogue Baltic Blue MY11
Post #201045 26th Jul 2013 10:29pm
TugRR
Isn't it good to know LR are keeping up traditions on Range Rovers . . .
Elevated driving position - check
Speed boat stance - check
Floating roof - check
Castellated bonnet - check
Rusting upper tailgate - check
Hopefully the new model will continue in the same vain Laughing
Thumbs Up Where do you go after one of these . . . ?
Post #201116 27th Jul 2013 1:07pm
