Home > Technical (L322) > MOT Failure
twhincup
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
MOT Failure
Big Cry
So Rear disc needs changing - the boy is coming tomorrow to help and also change pads
Parking brake efficiency below requirements - new disc and pads should sort that
fuel cap sealing washer deteriorated - new fuel cap ordered
n/s front upper (outer bush) suspension arm has excessive play - new bush ordered - just gotta find someone with hydraulic press to put it in
heres the bitch:
nearside and offside headlight cleaning device obviously defective Censored what a load of bo11ox it needs a wash to pass an mot - wtf do motorbikes do ffs Censored rant over
Anyway heres the deal, the o/s wiper works but no water, the n/s nothing
1) swapped 12v over on pumps proved pump works and water can flow on both sides - so electric feed issue
2) took wiper motor off n/s and gave it 12v direct feed and it works - 12v feed is at the cable to the motor - so electric feed issue
3) swapped pumps over from known working one and all working there.
Apart from fuse 28 is there any other fuse i can look for? does anyone know of known issue with headlight wipers??
After a week of replacing a water pump and 3 new tyres i'm losing a bit of faith in the car Sad
heres where i'm at:
 2007 3.0L Diesel VW Touareg SE
2003 4.4 LPG, Vogue, Silver
Post #200802 25th Jul 2013 4:30pm
Please don't think I'm being condescending here, but could it simply be blocked washer jets?
Otherwise, no idea. But I do hope you get it fixed soon. Thumbs Up Si. <This is my name.
Post #200812 25th Jul 2013 5:50pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
All Xenon and Bi-Xenon lamps must be self-levelling and have a wash or wash/wipe system fitted.
If you have Halogen lamps they don't need to be fitted.
It maybe the case that; if fitted they must work for MOT.
A cheap fix or a 'for now to get me through the MOT' would be, if your lights are Halogen, to remove headlight wiper arms, the the motors and put a small grommet where the motor spindle sticks out?
This would get you through the MOT and allow you to take your time to resolve the issue.
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #200813 25th Jul 2013 6:01pm
I have the same problem. Only one wiper works, other stuck at 30 degrees, no water from jets. Pulling fuse 28 made no difference and did not reset the wonky wiper. Next job is to clear ECUs with a battery disconnect and terminal touch. If that doesn't sort it, then I'll be doing the same as you, testing and tracing.
Fortunately (sorry to rub salt in wound) my MOT guy let this one pass on this occasion (probably only because I told him that I had HIDs last year and he hadn't spotted it!) .
Post #200815 25th Jul 2013 6:04pm
twhincup
not condescending at all, i'm open to any info at this stage Thumbs Up
HID's Sad no quick fix
lol, i spoke to the tester after and even he said it was crap that they fail mot on the wiper, if i disconnect the battery, what does/is the terminal touch?? 2007 3.0L Diesel VW Touareg SE
Post #200820 25th Jul 2013 7:21pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
your MOT tester sounds like an ass. Deteriorated filler cap washer?? Who checks that!
I reckon you take the wipers off and take it to a less nazi tester.....
edit. Later models dont even get wipers so it can't be a requirement to have them
edit 2 not sure fixing your rear disc will sort your park brake. i think its a transmission brake on this car..... sorry man! My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #200821 25th Jul 2013 7:24pm
dave699
Later models get a high pressure wash system.
It is definitely a requirement. Thumbs Up
Had it, loved it!
2007 Vogue SE TDV8
Post #200832 25th Jul 2013 8:13pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
Its not a transmission brake, but drums inside the discs. a good clean and proper adjustment should sort it if there is still material left on the shoes. Thumbs Up
The crazy thing is they are still manual adjusters!
Post #200839 25th Jul 2013 8:34pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Section 1.7 of MOT testers manual states that HID headlamps may have cleaning devices fitted, if fitted they must be operational. So if you remove the wipers, wiper motors and washer jets from the headlamps, they can't fail it.
I think the hand brake is drum in disc so you ma just need to adjust the shoes
Section 7.2 covers the fuel filler cap - Check fuel tank cap /filler neck sealing device for presence, positive fit and condition of sealing washer and flange. 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #200842 25th Jul 2013 8:54pm
hoppy_70
I don't doubt it's on the test, but don't think I've ever seen a tester even open the flap! My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #200844 25th Jul 2013 9:05pm
twhincup
pmsl me neither but its costing me a new fuel cap when they do Mr. Green 2007 3.0L Diesel VW Touareg SE
Post #200846 25th Jul 2013 9:13pm
twhincup
I asked them about this as I was just going to remove them and they said the HID's MUST have the device and is a failure in its own right if they dont 2007 3.0L Diesel VW Touareg SE
Post #200847 25th Jul 2013 9:15pm
Agree it is a "must work" as opposed to anything else for HIDs on the MOT.
Terminal touch:
Disconnect the battery, both terminals, following the procedure (wiki), then touch the pos and neg terminal cables together. This is supposed to help clear the ECUs, and may help to reset some things that won't reset any other way. No faults show up for this problem with IID tool (for me) .
Post #200868 25th Jul 2013 10:27pm
Andy_J
Straight from section 1.7
Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system. Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given. Headlamp washers may work in conjunction with the windscreen washers (when the dipped beam headlamps are switched on) or by a separate switch.
Reason for failure
2. A headlamp levelling or cleaning device inoperative or otherwise obviously defective.
Nothing to state that HID's must have a cleaning system or that the car will fail if it is removed. 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #200878 25th Jul 2013 11:35pm
A bit like removing seatbelts then ?......just following the logic Laughing
( I have a car old enough that I CAN do that with Very Happy )
I accept your point Andy_J Thumbs Up .
Post #200884 26th Jul 2013 12:14am
