Home > Technical (L322) > New box mpg |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 866 |
Bought a chip box from eBay. From experience I bought the cheapest one available on the basis that they all pretty much do the same thing. I've had one on most diesel cars that I have had and results have varied from not bad to dramatic. This one is pretty good. Makes my tdv8 much more responsive and on a run added significantly to the mpg. This is what I got on a 50 mile motorway trip today, 60-70 mph (being careful ish). Coming back It went down to 35 doing 10-20 more.
24th Jul 2013 7:43pm |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
Really? What chip box did you use? Or is it verboten to ask such questions on the forum? |
24th Jul 2013 8:01pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
You may find a different figure if you brim the tank and calculate the true mileage. Not saying it won't be better than standard though. |
24th Jul 2013 8:58pm |
I'm a bit of an old hand at these boxes and have had at least half a dozen. MPG usually reflects fairly well in the display to be fair. I've had results from 4-12mpg improvement on varying cars. They reckon a 60bhp increase on the tdv8 and it definitely feels like it.
24th Jul 2013 9:13pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
This one ?
24th Jul 2013 9:38pm |
goncalo Member Since: 26 Apr 2013 Location: Portugal Posts: 170 |
I think when you put a chip instead of remap the OBC donīt be accurate! It get confused! Ex-FULLFATTY now downgraded
24th Jul 2013 11:26pm |
Yes, that was it. He has good feedback as well. I've heard the comments about obc before, but don't see how that is possible. In any case this was checked against the fuel I bought after the journey and is right. My Previous RR's! 2018 P400e Autobiography 2008 TDV8 Vogue 2006 TD6 Vogue 2007 TDV8 Vogue 2007 RRS (I know, it doesn't count!) 2005 4.4 Vogue on LPG 2005 TD6 Vogue 2003 4.4 Vogue 2001 4.6 HSE 2000 2.5 DHSE 1999 4.6 HSE 1997 4.6 HSE on LPG 1995 2.5 DSE 1989 3.9 EFI classic 1988 3.5 EFI classic |
25th Jul 2013 6:00am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
the average mpg on your display is probably an accumulative figure for many weeks , whereas the figure you get after fitment of a box or a remap will be for that journey only after a reset ..you need to run for a few weeks to get a true figure..
25th Jul 2013 7:25am |
Stan,
25th Jul 2013 7:35am |
you could be correct..the only positive way to get a true mpg would be to do a tank to tank test..but note, my proper ecu remap didnt work but blanking of my egr valve got a few more mpg's [td6].. ... - .- -.
25th Jul 2013 7:41am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
I'm no expert here but from research, generally those boxes are just a resistor that drops the fuel rail pressure sensor voltage signal to the ECU. Some are slightly more clever but that box doesn't look to be as it's only and inline connection with the fuel rail pressure sensor.
25th Jul 2013 9:13am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
That's good information Weejock and inline with what I've been told in the past too.
25th Jul 2013 9:27am |
Weejock!
25th Jul 2013 2:04pm |
i certainly do recommend the egr blanking kit...they are only about Ģ30 on ebay and in my case i did get a few extra mpg's.. ... - .- -.
25th Jul 2013 2:26pm |
25th Jul 2013 2:47pm |
