Home > Maintenance & Mods (L322) > TPMS Woes |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
From what I hear they frequently cause issues a lot on here simply removed the tpms valves and replaced with std. Present :2008 TDV8 HSE
16th Jul 2013 9:33pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Yes, you're right. I just checked and they aren't required by law in Canada. However, I was wanting to get a fix instead of just binning them. |
16th Jul 2013 11:03pm |
Although your car is quite new the batteries may be running low. They normally last for around 7 years. On Ebay you can find sets that are quite reasonably priced but make sure you have to correct frequency, you need the North American frequency (same band as the keys), 315 MHz if I remember correctly (but please check).
17th Jul 2013 9:03am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
They do appear to be more bother than they are worth for some people. Personally, at the first sign of ongoing problems I would bin them rather than spend money repairing/replacing. Previously..
17th Jul 2013 9:15am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 |
As above! Got - 2017 SDV8 Autobiography in Loire Blue
17th Jul 2013 9:21am |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
As above
17th Jul 2013 11:25am |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
If you are getting 'check all tyres' message I'd suggest that points more towards the RF reciever module or possibly TPMS ECU. |
17th Jul 2013 11:50am |
People are turning the TPMS off too.
17th Jul 2013 7:24pm |
@ Katash - the check all tyres message indicates one of the road wheels is either low on pressure or not returning a signal.
17th Jul 2013 9:32pm |
Ah I thought it would return individual sensor status, mine warns when the spare in the boot is low and states 'Check spare tyre pressure' or something similar.
17th Jul 2013 10:01pm |
alx Member Since: 13 Jul 2014 Location: Beds Posts: 99 |
I've recently replaced all 4 TPMS sensors but still get an intermittent message light on the dash. Very annoying given the outlay on 4 new sensors. Now I have 6 months warranty from Stratstone and would like them to look into it, does anyone know if this is covered?
11th Nov 2014 3:46pm |
Remember, you have FIVE. It could be the one on the spare causing the problem if everything else is good. The spare tyre TPMS won't automatically synch with the car like the other four. |
11th Nov 2014 7:38pm |
Vorbis Member Since: 18 Jun 2014 Location: Pebmarsh Posts: 147 |
I've replaced all the tyre pressure sensors and still have the warnings. Front nearside is registering 0 volts apparently, next step is a new ecu |
11th Nov 2014 8:09pm |
Ah, yes of course! Will check pressure in the spare wheel tonight. |
12th Nov 2014 11:03am |
