Home > Technical (L322) > Does this wheel arch look right?
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Looking inside the rear wheel arch, facing forward I can see this metal flange. It spans about 90 degrees, is painted metal and exposed to any stones thrown up by the rear tyres.
Is this correct or should the wheel arch liner be protecting it? It's the same both sides. 4.4 TDV8 Vogue Baltic Blue MY11
Post #199090 16th Jul 2013 6:11pm
BrianC
Looks the same as mine was
Post #199091 16th Jul 2013 6:14pm
Googsy
Quite common I lightly sanded mine and redid in black hammerite x 2 coats. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #199092 16th Jul 2013 6:19pm
klf400
its a poor design , what i did with mine , i cut a rubber trim strip to length , applied loads of waxoil to the flange and strip and then pushed on the strip to cover it , hopefully the strip will shield it from stones and crap Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #199096 16th Jul 2013 6:34pm
pld118
Re: Does this wheel arch look right?
Hi,
The set up of the arch and the rubber 'look right' but not sure the problem is acceptable:
I'm reading from your April 2013 post that the car was registered in Nov 2010 which means it is still less than 3 years old?
If not before, you're now doubtless aware that rusting rear wheel arches is a known issue that afflicts the L322.
Our car was bought as approved used from a MD and I noticed this problem within a couple of days of getting it home. Arguably, I might have noticed it when I arrived to collect the car but when buying a pristine so called 'A car' from a main dealer, looking for concealed rust was not on my radar/ the wheelarches just looked dirty when I closely inspected the car at the MD (only after I noticed during detailed cleaning did I have cause to do more research and find it was a known problem).
Anyway, many members are able to demonstrate that it is an easy fix that can be done within an hour or two and that is fine. However, if you've paid £40k for a car, your recourse for such a young car should be with LR imo.
Ours was fixed free of charge by the main dealer's body shop as their smart repair professional said it was not suitable for a smart repair and the rust would return within 12 months (I also know that Bellini's SC had the same issue when bought from a MD and that too was fixed FOC).
The below thread related to our rusty rear arches. If you would like to know further details about how we took our issue to the MD and how it was resolved, if you PM me and I’ll try and assist. Hopefully you’ll get it sorted either way though.
http://www.fullfatrr.com/forum/topic17946....wheel+arch
Post #199099 16th Jul 2013 6:50pm
Baron
Good info I wasn't aware of so thanks. I'll be adding this to my snag list for next months dealer visit. Should be covered by the 3 year surface corrosion warranty I'd have thought as the cars' 3rd birthday isn't until Nov this year. 4.4 TDV8 Vogue Baltic Blue MY11
Post #199140 16th Jul 2013 10:45pm
