Home > In Car Electronics (L322) > Front screen rolling picture when DVD playing
Taximan2011
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
When I put a DVD in the DVD player in boot the rear headrest screens work perfect as they should however the front screen just has a rolling picture any clues New L322 Owner -
Post #198861 15th Jul 2013 8:44am
if it was an old crt tv i would suggest turning the horizontal hold but as its a lcd then thats not applicable...is this problem when you are stationary or moving.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #198865 15th Jul 2013 8:56am
Taximan2011
Both stationery and moving. The Tv Is obviously analogue as I get no tv picture although someone has put a digital tuner in the boot but doesn't seem to do anything but light up. But that shouldn't effect DVD operating New L322 Owner -
Post #198868 15th Jul 2013 9:04am
it sounds like you have an aftermarket dvd setup and thats outputting a PAL picture which the fullfats screen isnt decoding as its NTSC...to see if this is the case i think you can go into the diagnostic screen and toggle to PAL but i'm not to familiar with the pre touch screen models.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #198870 15th Jul 2013 9:16am
Taximan2011
Ok thank you for that advise I will have a look at that. New L322 Owner -
Post #198872 15th Jul 2013 9:19am
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
OEM DVD changer has option to change from PAL to NTSC in menu, get the wrong one set and you will get similar issue
Post #198881 15th Jul 2013 11:58am
Taximan2011
Screen is set to PAL New L322 Owner -
Post #198917 15th Jul 2013 3:42pm
Suggest working through all the options in the DVD player menu, maybe some "little fingers" have had a fiddle?
Has it always done it or just started doing it?
Maybe it was always like that and couldn't be resolved by the previous owner/installer?
Agree with others though, likely PAL/NTSC problem.....Front screen expects NTSC feed IIRC .
Post #198943 15th Jul 2013 6:32pm
Taximan2011
DVD on NTSC and front satnav screen on PAL New L322 Owner -
Post #198987 15th Jul 2013 9:49pm
