Home > In Car Electronics (L322) > Front screen rolling picture when DVD playing |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
if it was an old crt tv i would suggest turning the horizontal hold but as its a lcd then thats not applicable...is this problem when you are stationary or moving.. ... - .- -.
15th Jul 2013 8:56am |
Taximan2011 Member Since: 15 Jul 2013 Location: Somerset Posts: 15 |
Both stationery and moving. The Tv Is obviously analogue as I get no tv picture although someone has put a digital tuner in the boot but doesn't seem to do anything but light up. But that shouldn't effect DVD operating New L322 Owner - |
15th Jul 2013 9:04am |
it sounds like you have an aftermarket dvd setup and thats outputting a PAL picture which the fullfats screen isnt decoding as its NTSC...to see if this is the case i think you can go into the diagnostic screen and toggle to PAL but i'm not to familiar with the pre touch screen models.. ... - .- -.
15th Jul 2013 9:16am |
Ok thank you for that advise I will have a look at that. New L322 Owner - |
15th Jul 2013 9:19am |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
OEM DVD changer has option to change from PAL to NTSC in menu, get the wrong one set and you will get similar issue |
15th Jul 2013 11:58am |
Screen is set to PAL New L322 Owner - |
15th Jul 2013 3:42pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Suggest working through all the options in the DVD player menu, maybe some "little fingers" have had a fiddle?
15th Jul 2013 6:32pm |
DVD on NTSC and front satnav screen on PAL New L322 Owner - |
15th Jul 2013 9:49pm |
